Autodesk Inventor
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Printer Friendly Page
Re: Posting a project for comments
- Highlight
- Email to a Friend
- Report Inappropriate Content
If you want to take one part at a time and discuss how it should be done - we can do that.
In my experience most students who come here lose interest fast in doing it right, but you did come here for a critique, so maybe you are motivated to learn how it should be done.
Which part would you like to start with?
- Highlight
- Email to a Friend
Let's start with a nice easy part.
Nut.ipt
Delete the thread feature.
Edit the sketch and add a Vertical constraint to one of the vertical lines.
Notice anything happen?
(the sketch changes color indicating it is fully constrained).
Delete the circle. Notice anything happen.
Drag the centerpoint of the hex away from and back to the origin center point.
Because Inventor is now confused by the missing circle you might have to re-edit the extrude but simply click OK.
- Highlight
- Email to a Friend
Start a new sketch on one of the faces and Project Geometry one of the hex edges.
Sketch a circle tangent to the edge.
e
- Highlight
- Email to a Friend
Extude the circle Through All with the Intersect option and click the More tab and set to 45° to add a turned chamfer to the corners.
Repeat on other side.
- Highlight
- Email to a Friend
Start the Hole command and set to Concentric.
Click the plane and the circle and set to tapped and size.
- Highlight
- Email to a Friend
Add a .25mm chamfer to both sided of the hole.
Change to Chrome texture.
Now isn't that just prettier. Should make you feel proud!
- Highlight
- Email to a Friend
Which part would you like to do next?
- Highlight
- Email to a Friend
JD is on a roll! GO GET EM JD!
Windsor, ON. Canada
- Highlight
- Email to a Friend
In addition to JD's comments
M7 is NOT a preferred standard metric thread
So it's either M6 tapping hole of 5mm Clearance hole of 6.6mm actual 7mm nerest drill OR M8 tapping hole of 6.8mm 7mm nearest Clearancehole of 9mm actuall
NOTE
These are UK nearest Tapping hole size they may vary slightly according to different country's standards & drill sizes available.
Thanks in advance for any help & advice
Inventor 2012 Pro
Ashington Northumberland (UK) ~ Home to the WORLD FAMOUS Pitman Painters Group
- Highlight
- Email to a Friend
Many thanks for the correction
Joe
