• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Re: Posting a project for comments
    05-03-2012 01:31 PM in reply to: JDMather
    What type of class was this?  Just curious.. I took a quick look at your models, it looked like a pretty cool project but you should be careful with underconstraining your sketches.  It will come back to bite you eventually, if things are free to move around they eventually will and it will probably happen at the worst time (like you notice it right after the machine shop calls and says "hey this part looks all wacky, are you sure that's what you wanted??") Get in the habit of doing things right everytime, a little time up front saves tons in the back end.  I know it might seem faster to just wing it sometimes, but the extra time is worth it.  If you can grab a line or part of a sketch and drag it around then you really aren't done sketching yet, I think someone on here called it the etch a sketch technique, its a common practice.
    It looks like you are looking for some general tips so I will give you a few that I usually give people that work for me...start your sketches at the origin and dimension your profile to that origin point.  If its symmetric then this will save you tons of time later because you can draw a feature and then mirror or pattern it around the origin to quickly duplicate parts.  That is a huge time saver, which brings up my next point...never draw the same thing twice!  If you can create a feature then pattern it somehow that's the way to do it for sure.
    Also keep your sketches simple, that's another big one, it looks like nothing was overly complicated in your model, but that's a good point to keep in mind for future work.
    The last thing I will say is that before you start modeling, think for a few minutes about what you need the final outcome to be and what would be the most efficient way of getting there.  A little planning goes a long way.
    Good luck on your project.
    Please use plain text.
    Active Contributor
    donovandigital
    05-03-2012 01:33 PM in reply to: JDMather
    JDMather, you are made of 100% concentrated awesome. Clearly if I intend to charge money I am interested in the "right way" to do it.
    I don't have time this week to go through your nut tutorial, but I will get to it next week or week after. For now, thank you for the compliment of putting me in the 1% of students that are not put off by deep detail work.
    I am repackaging the original files for size as we speak. I will attach them to the reply I am writing to your original comment.
    Active Contributor
    donovandigital
    05-03-2012 03:21 PM in reply to: JDMather
    Thanks for all the info, I will be making the suggested adjustments in the next week or so.
    For now, just a couple questions.
    a)What do you mean by pattern features?
    b)Can you give an example of something that needs to be constrained that isn't?
    c)again, what kind of timeframe am I looking at for such a project to enable me to charge money? Clearly correcting and learning from my errors is paramount at this point, but I'd like a goal I can work toward in the long term.
    d)Also, again, what is the proper format for the printed document?
    Thanks again for all the help
    Joe
    Valued Mentor
    Rich.O.3d
    05-03-2012 06:27 PM in reply to: donovandigital
    go get em JD...love your work
    CAD Management 101:
    You can do it your own way,
    If its done just how I say!
    [Metallica:And Justice For All:1988]
    Active Contributor
    donovandigital
    05-03-2012 07:20 PM in reply to: Rich.O.3d
    Next part I think should be the board... it is most complicated. But, frankly, I don't care - it's your call.
    Active Contributor
    donovandigital
    05-03-2012 07:27 PM in reply to: donovandigital
    Completed nut - did not seem to have posted last time
    Active Contributor
    donovandigital
    05-03-2012 07:28 PM in reply to: donovandigital
    BTW, why did you do the corner chamfers with extrude rather than regular chamfer?
    05-04-2012 12:25 AM in reply to: donovandigital
    Do it.  Delete or suppress the Extruded Intersection and use the Chamfer tool instead.
    Notice the difference in results.  Which one looks like the real world part?
    05-04-2012 12:26 AM in reply to: donovandigital
    Next part I think should be the board... .
    Good choice as this will also answer your question about Feature Patterns.
    05-04-2012 12:27 AM in reply to: JDMather
    Your method of adding the chamfer to the outside edge of the nut is something I've never seen. I've always 'sketched' the chamfer and then revolve cut the chamfer away.
    You learn something new every day - brilliant!
