• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Re: Posting a project for comments
    05-03-2012 11:30 AM in reply to: JDMather
    If you want to take one part at a time and discuss how it should be done - we can do that.
    In my experience most students who come here lose interest fast in doing it right, but you did come here for a critique, so maybe you are motivated to learn how it should be done.
    Which part would you like to start with?
    Please use plain text.
    05-03-2012 11:34 AM in reply to: JDMather
    Let's start with a nice easy part.
    Nut.ipt
    Delete the thread feature.
    Edit the sketch and add a Vertical constraint to one of the vertical lines.
    Notice anything happen?
    (the sketch changes color indicating it is fully constrained).
    Delete the circle.  Notice anything happen.
    Drag the centerpoint of the hex away from and back to the origin center point.
    Because Inventor is now confused by the missing circle you might have to re-edit the extrude but simply click OK.
    05-03-2012 11:38 AM in reply to: JDMather
    Start a new sketch on one of the faces and Project Geometry one of the hex edges.
    Sketch a circle tangent to the edge.
    Sketch2.pnge
    05-03-2012 11:39 AM in reply to: JDMather
    Extude the circle Through All with the Intersect option and click the More tab and set to 45° to add a turned chamfer to the corners.
    Repeat on other side.
    05-03-2012 11:43 AM in reply to: JDMather
    Start the Hole command and set to Concentric.
    Click the plane and the circle and set to tapped and size.
    05-03-2012 11:46 AM in reply to: JDMather
    Add a .25mm chamfer to both sided of the hole.
    Change to Chrome texture.
    Now isn't that just prettier.  Should make you feel proud!
    05-03-2012 11:47 AM in reply to: JDMather
    Which part would you like to do next?
    GSE_Dan_A
    05-03-2012 12:44 PM in reply to: JDMather
    JD is on a roll! GO GET EM JD! :smileyvery-happy:
    GSE Consultants Inc.
    Windsor, ON. Canada
    Distinguished Contributor
    Mason-Paul
    05-03-2012 12:49 PM in reply to: JDMather
    In addition to JD's comments
    M7 is NOT a preferred standard metric thread
    So it's either M6 tapping hole of 5mm Clearance hole of 6.6mm actual 7mm nerest drill OR M8 tapping  hole of 6.8mm 7mm nearest Clearancehole of  9mm actuall
    NOTE
    These are UK nearest Tapping hole size they may vary slightly according to different country's standards & drill sizes available.
    Thanks in advance for any help & advice
    Inventor 2012 Pro
    Ashington Northumberland (UK) ~ Home to the WORLD FAMOUS Pitman Painters Group
    Active Contributor
    donovandigital
    05-03-2012 01:07 PM in reply to: RayFeiler
    Many thanks for the correction
    Joe
