• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Distinguished Contributor
    Possible Graphics Problem
    1049 Views, 8 Replies
    10-12-2011 09:53 AM
    If I switch back and forth from an .idw and .iam file while open simultaneously Inventor will say "Not Responding" and will do what I describe a a mini crash.  The program will stay open but I lose all Inventor video on my screen temporarily until the program recovers.  Does anyone know why this might be happening?
    Steve Frey
    Inventor 2013
    Windows 7 Professional 64-bit SP1
    HP EliteBook 8470w
    Processor: Intel(R) Core(TM) i7-3610QM CPU @ 2.30GHz
    Memory: 16 GB
    AMD FirePro M2000
    3D Connexion SpacePilot
    Please use plain text.
    *Expert Elite*
    Re: Possible Graphics Problem
    10-12-2011 10:17 AM in reply to: SteveFrey
    I get this occasionally with the last 2 or so releases (or maybe ever since Win7)...I thought thats normal.. :smileyvery-happy:
    Please click "Accept as Solution" if this response answers your question.
    2012 Product Design Suite Ultimate
    Windows 7 64 bit
    90G OCZ SATA 3 SSD (My SSD is faster than your HDD)
    Core I7 920 processor, ATI HD6970 graphics card, 12G Corsair RAM
    10-13-2011 06:36 AM in reply to: mcgyvr
    Typical Autodesk.
    Steve Frey
    Inventor 2013
    HP EliteBook 8470w
    Memory: 16 GB
    AMD FirePro M2000
    *Expert Elite*
    10-13-2011 08:16 AM in reply to: SteveFrey
    yep mines done it about 10 times this morning already (I'm doing raytracing and saving a copy as png) During that process Inventor gets horribly bogged down and unresponsive. Windows pops up the not responding message and Inventor goes funky. At one time the Inventor program button in my taskbar even looked like Inventor had closed ( I thought it crashed) and another dialog poped up..something like ADApplication but then I just waited and it all came back finally.
    I've been seeing this for the last few releases (like i said might just be since I upgraded to Win7-64) so Autodesk will blame it on Microsoft I'm sure but it seems to me Inventor isn't handling "high load" situations correctly as far as Microsoft is concerned. I can't remember any other program I have popping up a "not responding" message when its churning away. of course Inventor is alot more demanding that just about anything else I run.
    Windows 7 64 bit
    *Expert Elite*
    10-13-2011 08:36 AM in reply to: mcgyvr
    I've been seeing this for the last few releases (like i said might just be since I upgraded to Win7-64)...
    I noticed the same behavior when I first upgraded to Windows 7.  I think there is some new feature in this OS that tries to detect if a program is not responding and to try to "fix" it for you.  Sometimes this "fix" seems to involve terminating the program.  I dug around in the settings and found some options to turn this off and I have never seen it since.  See my reply to this post for more details about how to do that.  I hope it's helpful.
    *Expert Elite*
    10-13-2011 09:05 AM in reply to: cwhetten
    Interesting.... I had both those settings turned on and now have turned them off. I will restart and see if that helps any.
    also  the button that comes up in the task bar is ADApplicationButton. (incase that helps anyone at autodesk fix this issue)
    Windows 7 64 bit
    10-13-2011 09:40 AM in reply to: cwhetten
    Thanks.  I will check this out and see if it helps.
    Steve Frey
    Inventor 2013
    HP EliteBook 8470w
    Memory: 16 GB
    AMD FirePro M2000
    *Expert Elite*
    10-13-2011 11:14 AM in reply to: SteveFrey
    Didn't help me.. worth a shot though
    Windows 7 64 bit
    Member
    pavanpz
    10-23-2012 09:59 AM in reply to: mcgyvr
    Good afternoon, I'm having trouble trying to open a new project in Inventor 2010 Professional, whenever I open Inventor and click on New Project and click on the Inventor Standard (appears AdApplicationButton not responding) hangs only releasing with Ctrl + Alt + Del, the operating system is Windows 7 64-bit SP1 and Inventor are all SP inclusivce SP4. Computer is a Dell Precision T3500 with 8 gb ram and Nvidia FX1800, how do I solve the problem? Thank you and I await response
