• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Valued Contributor
    Accepted Solution
    Polylines in dxf files
    177 Views, 2 Replies
    09-13-2012 05:48 AM
    Using my ipt flat pattern, I export the face as a Rel. 12 dxf for the file to be used in our cnc software.
    I'm having a problem that the guy in the shop cannot open the dxf unless I open the dxf in Autocad and explode it.
    Inventor is creating the perimeter as a polyline.
    Is there any setting I can change to prevent the polyline creation?
    I have also noticed that, in some instances, through the bend area, that after I explode the file, there will be like 127 lines on top of each other.
    Again, is there a setting I can change to prevent all of this?
    Thank you very much for your help.
    Lenovo Think Pad
    Windows 7 SP 1
    64 Bit.
    Inventor 2013
    ACAD Mechanical 2013
    Please use plain text.
    *Expert Elite*
    mrattray
    Re: Polylines in dxf files
    09-13-2012 05:54 AM in reply to: sps_cad_guy
    Instead of using export face, right click on the flat pattern node in the browser and select Save Copy As. After you name and place the file an export options wizard will come up with all sorts of options that you can define and save to a ini file, including wether or not to use polylines.
    Mike (not Matt) Rattray
    Valued Contributor
    09-13-2012 08:38 AM in reply to: mrattray
    Thank you very much.
    That worked perfectly after a couple of
    tweaks with the layers and saving the
    configuration.
    Lenovo Think Pad
    Windows 7 SP 1
    64 Bit.
    Inventor 2013
