• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Valued Contributor
    jyothissurendran
    Re: Plot Date Expression ?
    10-24-2012 05:37 AM in reply to: karthur1
    Thanks man, it works well. Thank you very much for your time.
    Jyothis Surendran
    Inventor Professional Suite 2010
    Windows 7
    Please use plain text.
    Valued Contributor
    machiel.veldkamp
    10-24-2012 06:04 AM in reply to: jyothissurendran
    I always use quick fixes for this kind of stuff.
    ___________________________
    Inventor 2012 lastest service pack
    RAM: 16GB DDR3 / CPU: Intel Xeon W3690 @3.47Ghz
    Video: NVidia Quardo 2000 / HDD: 15.7K
    Windows 7 Pro 64-bit
    karthur1
    10-24-2012 07:00 AM in reply to: machiel.veldkamp
    Machiel,
    That is an interesting way of doing that. So each time you print the idw, you have to go into the iproperties and check the date box.... right?  Just trying to figure out how you get this to update.
    What I am doing does it automatically when the idw is saved.
    Valued Contributor
    machiel.veldkamp
    10-24-2012 07:06 AM in reply to: jyothissurendran
    Yes indeed.
    That is exactly how I do it.
    I use the iProperties a lot this way. Semi-Automated text, is how we call it here. It's is very handy when you want to update a lot of sheets at the same time, and in the meantime still want to have that control.
    karthur1
    10-24-2012 07:21 AM in reply to: machiel.veldkamp
    Seems liike a bunch of work... but if it works for you, go for it.
    BTW, Here is another way to add the plot stamp using iLogic.
    All of these methods stores variables in the iproperties of the idw when the file is saved.  Problem with that is if you are using Vault, the file has to be checked out, then saved, then printed. Otherwise, the date/time will not be updated.  that is why we use the terms "Last Saved on..." instead of "Printed On...".  To bad they do not have a "Before Print" event Trigger in iLogic.
    Anyone familar with ACAD's plotstamp tool knows that is not the case with it. Really wish AD would add this functionality into Inventor.
    Kirk
    Windows 7 x64 -12 GB Ram
    Intel i7-930 @ 3.60ghz
    nVidia GTS 250 -1GB (Driver 301.42)
    INV Pro R2013, SP1.1
    Vault 2013
    Distinguished Contributor
    BLHDrafting
    10-24-2012 02:53 PM in reply to: karthur1
    Hear hear Kirk. It's just bloody annoying for something this simple to not already be in Inventor. We should all add this as a Wsih List request. The squeaky wheel gets the grease (or replaced :smileywink:)
    Glad you clarified the macro interaction with Vaulted IDW's. It's fine the first time the IDW is created and printed, but future opening of the IDW and printing it would dirty the file, forcing check out /in which can have implications.
    Brendan Henderson
    Web www.blh.com.au
    Twitter @BLHDrafting
    Windows 7 x64 -64 GB Ram, Intel Xeon E5-1620 @ 3.6 GHz
    ATI FirePro V7800 2 GB, 180 GB SSD & 1 TB HDD
    Inv R2013 PDS SP1.1 Update 2, Vault 2013 Workgroup Update 1
    Valued Contributor
    jyothissurendran
    10-27-2012 09:59 PM in reply to: BLHDrafting
    Thanks Members,Thanks for all your  valueable suggessions.
    Jyothis Surendran
    Windows 7
