• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Valued Contributor
    jyothissurendran
    Accepted Solution
    Plot Date Expression ?
    327 Views, 16 Replies
    10-22-2012 02:06 AM
    i have created Template as per my compnay standards and would like save its as my company standard template (*.idw) file. Everything is done but i need add PLOT DATE on the template file. In autocad its possible by adding fields in text.So i followed the same procedure to add PLOT DATE in inventer template. But i dont find any option for adding PLOT DATE. There is any option available to add field expression or something to get the output plot date ????
    Jyothis Surendran
    Inventor Professional Suite 2010
    Windows 7
    Please use plain text.
    Distinguished Contributor
    BLHDrafting
    Re: Plot Date Expression ?
    10-22-2012 03:13 PM in reply to: jyothissurendran
    Not sure there is an Inventor property for this. Swift Printes (http://cadtoolbox.com/swift-prints/) can do this (and is a very nice printer config tool).
    Brendan Henderson
    Web www.blh.com.au
    Twitter @BLHDrafting
    Windows 7 x64 -64 GB Ram, Intel Xeon E5-1620 @ 3.6 GHz
    ATI FirePro V7800 2 GB, 180 GB SSD & 1 TB HDD
    Inv R2013 PDS SP1.1 Update 2, Vault 2013 Workgroup Update 1
    Valued Contributor
    jyothissurendran
    10-22-2012 09:56 PM in reply to: BLHDrafting
    But i was actually searching for something like in autocad, field expressions.
    If somebody have any idea please do advise...
    Jyothis Surendran
    Windows 7
    *Expert Elite*
    karthur1
    10-23-2012 05:57 AM in reply to: jyothissurendran
    Jyothis,
    You will not find an expression for this (wish there was though). What we have been using for several years is a "Last Saved on...." stamp. It looks like this on the idw.
    If that would work for you, post back and I will explain how to set this up.
    Valued Contributor
    10-23-2012 09:12 AM in reply to: karthur1
    An option that does give you the exact plot time, plus more.
    http://www.c3mcad.com/ProductPages/Drawing/ProductPlotStampPlus.aspx
    *Expert Elite*
    karthur1
    10-23-2012 09:26 AM in reply to: nmunro
    C-Cubed has done a great job at filling this void that AD left open. I just really wish that AD would include this with Inventor. (Yes, I have requested this on the AD contact page)
    The OP was probably thinking that he could add this easily to the idw like in Acad.
    BLHDrafting
    10-23-2012 07:03 PM in reply to: karthur1
    The only real problem I have with any of the add-in type options is when used in a Vault environment. generally plotting the IDW requires a change to a custom iProperty which then makes the IDW file dirtied. This is why I have stopped using this part of the Swift Prints add-in.
    I agree that Autodesk just need to bite the bullet and make this a useable function out of the box.
    Brendan Henderson
    Web www.blh.com.au
    BLHDrafting
    10-23-2012 07:10 PM in reply to: nmunro
    I haven't seen this one before. The website boldly says "All Plot Stamp Plus actions are completed without dirtying the Autodesk Inventor document" and is this is the case then I might just buy it!
    Brendan Henderson
    Web www.blh.com.au
    Valued Contributor
    jyothissurendran
    10-24-2012 02:23 AM in reply to: karthur1
    Thanks for the reply. But i dont find any option like "last saved on", i am using INV 2010.
    Jyothis Surendran
    Windows 7
    *Expert Elite*
    karthur1
    10-24-2012 05:25 AM in reply to: jyothissurendran
    Jyothis,
    I have a macro that adds a custom property named "SysDate" and "SysTime".  The code is attached.  Here is how to get this to work:
    1. Open your idw template.  Go to Tools>VBA Editor.
    2. Under the Autodesk Inventor Node is a "This Document" module, right click on this and choose "View Code".
    3. Now copy/paste the code in the attached txt to this node.
    Now when you save the idw, you should have a "SysDate" and "SysTime" variable under the custom iproperties that you can use in your expression.
    It should look something like this when you are done.
    Kirk
