• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Member
    Placed Tooling Part Invisible ?
    130 Views, 6 Replies
    05-13-2009 03:23 AM
    When I place a plastic part (or Core/Cavity) in a Mold Design iam. The screen stays empty.....
    Editing it via the browser shows the parts are there ?!?
    Also the Cube dissapears......
    So what is going on ?
    All drivers updated, XP64bit, QuadroFX4600, 8GRam
    Please use plain text.
    *Expert Elite*
    Re: Placed Tooling Part Invisible ?
    05-13-2009 06:32 AM in reply to: aaddekrom2279
    If you reboot does the ViewCube return?
    Does the part in the Mold Design Tutorial work?
    Can you zip and attach the assembly here?
    Inventor Professional 2014 Edu 64-bit
    Member
    05-13-2009 07:12 AM in reply to: aaddekrom2279
    Reboot nor reinstalling Tooling changed something.
    Cube is there but when i point at it or at the node from the mobile in the browser, CPU usage goes up for a
    while, after that Cube dissapears or freezes.
    I can edit the base component of the Mobile, no issues in the part environment there.
    Attached the iam and an image.
    Member
    05-13-2009 07:34 AM in reply to: aaddekrom2279
    Update;
    Placing the assembly in an idw works fine.
    *Henry Zhao\(Autodesk\)
    05-13-2009 11:09 PM in reply to: aaddekrom2279
    I can see the invisibility issue after opening your
    attached assembly.
    You can try to press "Home" Key or click "Zoom All"
    command in the Ribbon tab. It will zoom the part into the graphic
    window.
    I am not sure what's the reason about this issue.
    Could you please post your detail workflow about the creation? So that we can
    reproduce and investigate it.
    Henry
    style="BORDER-LEFT: #000000 2px solid; PADDING-LEFT: 5px; PADDING-RIGHT: 0px; MARGIN-LEFT: 5px; MARGIN-RIGHT: 0px">
    Reboot
    nor reinstalling Tooling changed something. Cube is there but when i point at
    while, after that Cube dissapears or freezes. I can edit the base component of
    the Mobile, no issues in the part environment there. Attached the iam and an
    image.
    Member
    05-17-2009 09:56 PM in reply to: aaddekrom2279
    I tried "zoom all", "find in window" etc....
    Just followed (exactly) the instructions from the "general mold workflow" tutorial that comes with tooling.
    When i place other parts than the mobile it makes no difference, nothing will show up.
    Changing Color or Display options make no difference.
    Roll Back Graphics driver make no difference.
    *Expert Elite*
    05-18-2009 04:52 AM in reply to: aaddekrom2279
    Zip and attach the assembly here.
