• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Member
    Accepted Solution
    Place iAssembly Key Value problems?
    66 Views, 2 Replies
    02-08-2012 10:49 AM
    I am creating an iassembly with multiple iparts. I have set up 5 different keys to include or exclude certain parts when I place the iassembly into an assembly. When I place the iassembly into an assembly the place iAssembly dialog box opens and all of my keys are listed as I would like. The problem I am having is that my keys don't show both options for include or exclude for the specific parts I would like to see or not see in the placed assembly. Within the iassembly Author spread sheet for the iassembly each cell for each specific KEY that I want is formatted with a pull down list of INCLUDE or EXCLUDE. I don't understand what I am doing wrong here?
    I have attatched a jpeg. The top shows the Iassembly Author table and the bottom shows the Place iassembly dialog box
    Employee
    Re: Place iAssembly Key Value problems?
    02-09-2012 01:16 AM in reply to: TColson82
    In the iAssembly table, the part only is included, not excluded. So only "Include" show when place the iAssembly into one assembly.
    If you add one row to exclude the member, you will can see the two options.
    In fact, in the place dialog, it only show all values added in the table.
    Steven
    Member
    02-10-2012 09:24 AM in reply to: StevenFeng
    Thanks that makes sense. I think I was mostly confused with the iAssembly Author dialog and how it works. I thought that having an option under the Author dialog column would allow you to pick one of the options when placing the iassembly not just for that specific Member within the assembly.
