Autodesk Inventor
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
Place dimension weirdness
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Watch this video to see the issue. When I try to place an angular dimension, the view justs and the dim is not placed correctly. This is the base view, but notice how when I try to move the view, there is a horizontal line going off into space to the right. This should be going back toward the projected view, but its not. If I copy/paste the view, it copies over the same behavior.
I can blow away the view and place it again on the sheet and everything works fine.
Re: Place dimension weirdness
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Wow, that is a bizzare one.
Have you tried importing the dimensions from your model?
Scott McFadden
(2 Corinthians 5:21)
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
How about making sure your part face (plane) is parallel with the IDW (sheet) plane? I've had similar weird results with complicated FG members that I have demoted to an assy file so I can detail them. Because the FG member uses the Frame UCS. From memory you can select the first dimension line and then RMB and there is an option for selecting the alignment? of the dimension with the part or the sheet plane. I forget the exact terminology as I don't do it too often.
CAD Manager/Product Development Manager
HP Z420 Workstation, Windows 7 x64, 64 GB Ram
Intel Xeon E5-1620 @ 3.60 GHz, ATI FirePro V7800 2 GB
3*Dell 2007Fp monitors, SpacePilot
Inventor 2013 PDS Premium & Service Pack 1.1 with Update 2
Vault Workgroup 2013 with Update 1
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
brendan.henderson wrote:.... From memory you can select the first dimension line and then RMB and there is an option for selecting the alignment? of the dimension with the part or the sheet plane.....
I dont have a right-click option like that when I am dimensioning. I did make sure that the part face was parallel with the sheet (Edit View>Change view orientation). It still jumps when I place the angular dim. It is easy enough to fix for this one part (delete view and redimenion). Good thing it is just this one view.
This idw was a "Copy Design" of another design. The original idw was created in 2010 and it does the same thing, so it is not a 2013 thing. I could send the file to AD if someone there is interested in looking at it and try to see why the view is hosed (ref. F3253-066)
