• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    conbuc
    Place a hole referenced from a plane instead of an edge.
    226 Views, 4 Replies
    10-19-2012 11:26 AM
    I would like to use the hole command to place a hole in a part. When I place the hole it won't allow me to use one of the origin planes to locate the hole from. Can I only locate holes off edges?
    Please use plain text.
    Curtis_Waguespack
    Re: Place a hole referenced from a plane instead of an edge.
    10-19-2012 11:34 AM in reply to: conbuc
    Hi conbuc,
    If you create a sketch on the plane and insert a sketch point, you can then create the hole from the sketch point using the hole tool.
    I hope this helps.
    Curtis
      solution.png  Did you find this reply helpful ? If so please use the Accept as Solution or  Kudos button below.
    mrattray
    10-19-2012 12:12 PM in reply to: Curtis_Waguespack
    This is the only workflow I use for holes. I never liked using the hole command's dialog for defining the hole position in Inventor or SolidWorks.
    Mike (not Matt) Rattray
    *Pro
    10-20-2012 11:07 AM in reply to: mrattray
    I agree, with a couple of exceptions-- creating a sketch for a hole concentric to another circular feature is way more work and no improvement over using the Concentric placement option.  And once in a while, the Point option also saves a lot of work.
    conbuc
    10-22-2012 07:19 AM in reply to: sbixler
    Thank you all for the responses. I will use sketches to place or locate my holes.
    It does suprise me however that Inventor would not allow the hole to be referenced off of edges AND/OR planes. Inventor already knows where the planes are and in many cases I want the holes to stay put based on the center of the part, not off one edge.
