• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    sgold
    Accepted Solution
    Place Active Component or from Memory
    104 Views, 4 Replies
    07-10-2012 08:58 AM
    Ok, maybe I'm being blind here, but is there a way to place a component from the inventor tabs into another tab without having to go find it in a silly folder all the time?  I spend a lot of time digging around folders when all the parts I want to assemble are open in tabs already.  Seems like a good selection to be in that upper left corner of the open window.  That and a "recent files" selection too!  Thanks!
    --Scott
    Scott G.
    Using Inventor 2013 and Vault Basic (New to Inventor)
    6 years Solidworks (v2006-2010)
    10 years Pro-Engineer (v13-WF2) w/ Intralink (2.0-3.0)
    2 years of Mechanical Desktop
    AutoCAD since R12
    First professional CAD: DrafixCAD
    Please use plain text.
    Active Contributor
    Re: Place Active Component or from Memory
    07-10-2012 09:06 AM in reply to: sgold
    Click on the Arrange button so you can view both the part and the assembly file.  Select the part file to make it the active window.  Click on the top most line in the browser (the line with the name of the part) and drag it into the assembly window.
    *Expert Elite*
    Simply copy/paste from the graphic window or the model browser. (graphic window doesn't work if its a part or if the selection filter is not set right in the assembly files)
    Please click "Accept as Solution" if this response answers your question.
    2012 Product Design Suite Ultimate
    Windows 7 64 bit
    90G OCZ SATA 3 SSD (My SSD is faster than your HDD)
    Core I7 920 processor, ATI HD6970 graphics card, 12G Corsair RAM
    sgold
    07-10-2012 12:06 PM in reply to: sgold
    Thanks.  Both solutions do work, though having to see both windows does suck a bit is the drag and drop mode...would be cool to drag that to the tab and the tab then change so you can place.  Similar to dragging files in windows, you can drag to a window in the task bar (old XP trick).
    --Scott
    Scott G.
    AutoCAD since R12
    *Expert Elite*
    Curtis_Waguespack
    07-10-2012 12:37 PM in reply to: sgold
    Hi sgold,
    If you use mcgyvr's copy/paste method you shouldn't need to see both windows at the same time.
    • Click the tab for the source component (the part you want to insert for example).
    • Select the top level node in the model browser.
    • Press CTRL + C on the keyboard
    • Click the tab for the desitination assembly.
    • Note the postion of your mouse cursor in the graphic area of the assembly
    • Press CTRL + V on the keyboard (the component will paste in at your cursor)
    I hope this helps.
    Curtis
      solution.png  Did you find this reply helpful ? If so please use the Accept as Solution or  Kudos button below.
