• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Autodesk Inventor
    New Member
    Accepted Solution
    Pipe runs
    139 Views, 3 Replies
    03-06-2013 09:07 AM
    Is there a way in inventor if you have an existing pipe route to create a new pipe run and place that existing route into the new run.
    Please use plain text.
    *Expert Elite*
    Cadmanto
    Re: Pipe runs
    03-06-2013 10:03 AM in reply to: holmes9294
    Welcome to the forum.
    If I understand you correctly, the short answer would be "No".
    Once you have an existing base pipe run, you can add to it and even runs added to runs within the base run.
    But you cannot have two base runs.
    Best Regards,
    Scott McFadden
    (2 Corinthians 5:21)
    *Expert Elite*
    cbenner
    Re: Pipe runs
    03-06-2013 12:03 PM in reply to: Cadmanto
    Not sure if that's what he meant, Scott.  Could be, but I read it slightly different.  The way I read it was as if wanted to take a route from one run, and insert it or paste it into a new run.  And if that's right, once again the simple answer is.... no.
    If not,... listen to Scott!  :smileyvery-happy:
    ChrisB
    Please use Mark Solutions!.Accept as Solution &Give Kudos!Kudos to further enhance the value of these forums. Thank you! :smileyhappy:
    Valued Contributor
    Re: Pipe runs
    03-06-2013 12:25 PM in reply to: holmes9294
    Yes, you can reuse a route either in a new T&P run or in an existing one. The workflow is spelled out in the help file. Just copy the route, and paste it into the new run, then constrain it into place, then make it adaptive. This will prompt you for new file names and such since you are creating new components.
    Read more here:
    http://wikihelp.autodesk.com/Inventor/enu/2013/Help/1310-Autodesk1310/3029-Tube_and3029/3159-Tube_an...
