• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Autodesk Inventor
    *Corbin, Brian
    Pink reference geometery
    37 Views, 3 Replies
    11-17-2002 05:28 AM
    Ok, I am trying to figure out this pink ref geom that comes from projected
    edges. Some projected circles will have a link back to the edge where others
    are pink but have no link? Is there some kind of rule as to when this will
    or won't happen?
    Brian
    Please use plain text.
    *Yeandle, Laurence
    Re: Pink reference geometery
    11-17-2002 04:45 PM in reply to: *Corbin, Brian
    Pink geometry is either projected geometry from another part in an assembly
    or projected geometry from a feature in same part that has been deleted or
    moved.
    Both are reference geometry which cannot be constrained or moved.
    As they are reference why would you move them as they would no longer be
    reference.
    Used as "cross part geometry projection" (see application options assembly
    tab ) Projected geometry can move with origin geometry when it changes "part
    adaptivity" when option is selected. To see an example see sample files in
    5.3 "ebox" and show all files on file type drop down to see doc file.
    You can sketch normal geometry over the top of reference geometry and
    dimension it or change selected geometry to normal you then lose reference.
    "Autoproject edges during curve creation" option on sketch tab in
    applications options I found is best left off as it lead to open loops in my
    sketches which were problematic to fix. Project geometry when you need them
    and leave "Cross Part Geometry Projection" off till you have explored its
    effects.
    Laurence,
    Power is nothing without Control
    "Brian Corbin" wrote in message
    news:smileyvery-happy:E08645AB905906ECAADC2327DF03B65@in.WebX.maYIadrTaRb...
    others
    > or won't happen?
    > Brian
    *Berry, Patrick
    Re:
    11-18-2002 12:55 AM in reply to: *Corbin, Brian
    Another I leave turned off is "Automatic reference edges for new sketch".
    This takes all of the edges of the surface you select to place a sketch on
    and automatically projects them. Normally you don't need that much geometry
    and it can cause problems later when you are trying to edit the part. I
    agree with Laurence that "Autoproject edges during curve creation" is not a
    good idea either. I had nothing but problems when trying to use it.
    One other are that hasn't been mentioned is the "Project Cut Edges" tool.
    Unfortunately, these edges will always be unreferenced (pink) edges. That
    severely limits the usefulness of this command.
    Pat
    "Laurence Yeandle" wrote in message
    news:389C7FB840EC6151DE58456A2C620A9B@in.WebX.maYIadrTaRb...
    assembly
    > moved.
    > reference.
    "part
    in
    reference.
    my
    them
    > effects.
    > Laurence,
    projected
    > others
    will
    > > or won't happen?
    > > Brian
    *Yeandle, Laurence
    Re:
    11-18-2002 02:31 AM in reply to: *Corbin, Brian
    Right, just cause its pink or black and reference doesn't necessarily
    mean it will up date with origin geometry automatically except when used
    with C P G Projection in the correct manner. When projected it referenced
    origin geometry then, black geometry turned pink means its moved or gone
    like your pink dims in IDW's, you might want to update if required.
    Laurence,
    "Patrick Berry" wrote in message
    news:8B280D47BF41038A3E1CBCCD7E77A135@in.WebX.maYIadrTaRb...
    > Pat
