• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Member
    Accepted Solution
    Physical properties notation
    299 Views, 6 Replies
    10-17-2012 06:40 AM
    I have some issues with the notation for physical properties in the Inventor 2013 material editor.
    Instead of displaying the obvious first choice metric SI notation kg/m^3 or something similar it display a self made? and awkward N*s^2/mm^4. I don't want this notation. How can I change to something more user friendly? It can be a bit hard to distinguish if a material have 0.00000000001 N*s^2/mm^4 or 0.0000000001 N*s^2/mm^4.
    The document properties "units" folder have mm, seconds, degree and kilogram as default.
    Running Inventor suite SP1.1 on 64bit vista.
    Please use plain text.
    Employee
    Re: Physical properties notation
    10-17-2012 05:42 PM in reply to: Bpom
    Down at the bottom left of the material or appearance browser/editor there is an option to set the units of display for physical properties. The units of display for materials/appearances are now unrelated to your document settings.
    Chris
    Chris Mitchell
    Inventor Quality Assurance Team
    Autodesk, Inc.
    Member
    10-17-2012 11:13 PM in reply to: chrismitchell01
    Thanks, that did do the trick  :smileyhappy:
    Active Contributor
    01-24-2013 04:22 AM in reply to: Bpom
    Anyone who knows how to get the previous Materials Editor back?
    Tried, unsuccessfully, to add a new material.
    The functionality of the new and 'improved' materials handling is totally beyond me, I simply do not get it :-(
    Active Contributor
    01-24-2013 04:25 AM in reply to: tommy-z
    And, the button (or whatever it's called) which Chris Mitchell speaks about, allowing change of the units of the Materials Editor, does not appear to be part of my installation.
    Distinguished Contributor
    LT.Rusty
    01-24-2013 07:37 AM in reply to: tommy-z
    It's in a REALLY counterintuitive location.  It's on the material browser window, not the material editor.  Click the pulldown that looks like a little gear, then you'll find what you're looking for.
    ___________________________________________________________
    Product Design Suite Ultimate 2013
    Dell Precision T1600 (Xeon E3-1280 / 16GB / 512 GB SSD / 250 GB (Internal) / 1 TB (External) / Quadro 600)
    Toshiba Satellite P755-S5269 (i7-2630QM / 8 GB / 250 GB SSD / 750 GB HDD / GT540M)
    Active Contributor
    01-25-2013 12:34 AM in reply to: LT.Rusty
    Thanks, I found it, in the - like you said - counterintuitive location.
    The whole new materials thing is extremely counterintuitive, I find.
    Another 'funny' observation: When entering the density of an insulation material, which is: 80 kg/m³ the wonderful application 'corrects' that to: 8,000E+01 kg/m³!?
    Talk about counterintuitive :-)
