Autodesk Inventor
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Printer Friendly Page
Physical Inventor properties
- Highlight
- Email to a Friend
In properties on physical tab Plumbum has density 0.940 g/cm3, but it should be 11.34 g/cm3. But in material editor it has right value. What should I do? Maybe it is config file somewhere?
Re: Physical Inventor properties
- Highlight
- Email to a Friend
In English, I think the material you're referring to is "Lead".
As far as the density: it appears that you are using Inventor 2013; when I create a part in 2013 made of lead, the density in iProperties matches the Material properties. Is it possible that the density has been manually edited in the file?
- Highlight
- Email to a Friend
Attach the file here or create a cube 1cm x 1cm x 1cm and attach it here.
- Highlight
- Email to a Friend
I have the same problem with Aluminum.
If i create a simple new part / cube 10 x 10 x 10 cm. it has the correct weight and density.
But if i derive an assembly in to the part as a surface model the density change.
Kind regards
Henrik Graversen
- Highlight
- Email to a Friend
Thank you for answers. After checking Lead in properties, I closed properties window. After reopening properties it is all right. And every time like this: Lead value is wrong, but after accepting and reopening Properties, value became correct.
