• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Active Member
    Accepted Solution
    Physical Inventor properties
    461 Views, 4 Replies
    09-16-2012 09:34 AM
    In properties on physical tab Plumbum has density 0.940 g/cm3, but it should be 11.34 g/cm3. But in material editor it has right value. What should I do? Maybe it is config file somewhere?
    Please use plain text.
    *Pro
    Re: Physical Inventor properties
    09-17-2012 05:13 AM in reply to: bodich
    In English, I think the material you're referring to is "Lead".
    As far as the density: it appears that you are using Inventor 2013; when I create a part in 2013 made of lead, the density in iProperties matches the Material properties.  Is it possible that the density has been manually edited in the file?
    *Expert Elite*
    09-17-2012 05:17 AM in reply to: bodich
    Attach the file here or create a cube 1cm x 1cm x 1cm and attach it here.
    Valued Contributor
    11-09-2012 01:27 AM in reply to: JDMather
    I have the same problem with Aluminum.
    If i create a simple new part / cube 10 x 10 x 10 cm. it has the correct weight and density.
    But if i derive an assembly in to the part as a surface model the density change.
    Kind regards
    Henrik Graversen
    Active Member
    12-01-2012 07:04 AM in reply to: bodich
    Thank you for answers. After checking Lead in properties, I closed properties window. After reopening properties it is all right. And every time like this: Lead value is wrong, but after accepting and reopening Properties, value became correct.
