• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    New Member
    Accepted Solution
    Peventing Assemby Rotation
    124 Views, 1 Replies
    10-17-2012 04:17 PM
    I want to make an assemby consisting of 3 parts. A crank shaft and a crank pin that screw into threaded holes in a crank disk. How can I insert them and prevent them rotating in their holes but still allow the whole assembly to rotate around the axis of the shaft? Also how could I lock a flywheel on to the shaft so that whole assembly can rotate togeather?
    Please use plain text.
    *Expert Elite*
    Re: Peventing Assemby Rotation
    10-17-2012 07:02 PM in reply to: mgudopp
    Apply assembly constraints.
    Mate workplanes is often a solution.
    Use logical sub-assemblies.
    Attach your assembly here.
