• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    JI7
    Active Member
    JI7
    Pattern a hole feature by linking to....
    140 Views, 6 Replies
    02-22-2012 03:37 PM
    I am trying to link a hole feature in a part in an assembly with the number of a particular feature in another part within the assembly.  Let me clarify that, I have a base plate part with a coutersunk hole feature that I want to pattern by linking it to the number of bosses in another part within the same assembly.  Any suggestion on how to do this?  I have tried and tried to figure it out myself but haven't succeeded.  Thanks.
    Please use plain text.
    Re: Pattern a hole feature by linking to....
    02-22-2012 06:13 PM in reply to: JI7
    You will need to link the parameters for the pattern.
    This is achieved by opening the parameters dialog within the part with the countersunk hole in it. Then select link parameters via a part and select the part that has the pattern parameters, then select the parameters required.
    JI7
    Active Member
    JI7
    02-24-2012 05:52 PM in reply to: PACDrafting
    I have tried to follow your instructions but I'm obviously missing something.  I identified the parameter for the circular pattern on the first part and then I went to the second part and clicked on the Parameters button from the Manage Tab.  I then clicked on the only button available with anything near like what you said which is a button with the work Link on it.  I then navigate to the first part and see the list of parameters there including the one for the circular pattern I am trying to link to but where to go from there I am not sure.  Am I doing this right?  I have included a link to a video of what I have done to look at to clarify my problem.  Thanks.
    http://www.youtube.com/watch?v=6bi5MTmaHBg
    02-25-2012 02:51 AM in reply to: JI7
    Include the parameters required. E.g. the pattern number and the pattern length.
    Once these are included, make these referenced parameters your parameters for the hole pattern.
    JI7
    Active Member
    JI7
    03-15-2012 04:09 PM in reply to: PACDrafting
    Sorry for taking so long to get back on here.  I have done my best but I'm not sure if I have done it right.  Should the hole pattern update if I edit the patterned feature in the first part?  Because I don't think mine did.  This is what I have done in following your instructions:
    http://www.youtube.com/watch?v=IfbZpqDgJ14
    Is this right or have I missed something out?
    03-15-2012 04:13 PM in reply to: JI7
    Hi
    I cant view this video. Its a private video. I dont have access.
    JI7
    Active Member
    JI7
    03-18-2012 02:51 PM in reply to: JI7
    Sorry about that.  You should be able to access it now.
