• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    ErikaBruning
    Parts list wont update - Inventor 2013
    375 Views, 5 Replies
    07-12-2012 05:59 AM
    I double click to update my parts list, when I select apply or ok, the updates do not happen.
    I have to close Inventor and re-open to see the changes.
    Erika Bruning
    Windows 7 64-bit
    Autodesk Design Suite Premium 2013
    Please use plain text.
    Employee
    Re: Parts list wont update - Inventor 2013
    07-13-2012 05:21 AM in reply to: ErikaBruning
    Hello Erica,
    Could you please describe your workflow in more detail? It would help to understand what kind of changes don't appear in the parts list.
    Changes made in assembly should update parts list in drawing when drawing is opened or when switching between documents so drawing can react on changes made in assembly.
    Oto Kaleja
    ErikaBruning
    07-16-2012 05:25 AM in reply to: okaleja
    I added parts to my assembly, went to my parts list and the new parts were at the bottom of the list (out of numerical order). I will double click on the list so that I can sort. It looks correct in the window, but when I click APPLY or OK it does not update. I need to close and reopen for the changes to take place.
    Erika Bruning
    Windows 7 64-bit
    Employee
    07-18-2012 02:41 AM in reply to: ErikaBruning
    Thanks for the update!
    Unfortunately I was not able to reproduce the issue. Would it be possible to send some simple dataset which shows the issue at otoDOTkalejaATautodeskDOTcom ?
    Oto
    ErikaBruning
    07-18-2012 04:51 AM in reply to: okaleja
    The error is in a very large assembly. Do you have a secure way that I can send this to you?
    Erika Bruning
    Windows 7 64-bit
    Employee
    07-20-2012 03:02 AM in reply to: ErikaBruning
    I have sent you a private message, plaese take a look.
    Oto Kaleja
