• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    *Expert Elite*
    Cadmanto
    Accepted Solution
    Parts List Wrapping Direction
    148 Views, 3 Replies
    12-06-2012 11:39 AM
    When a parts list in an Inventor drawing is wrapped it always takes the bottom portion and kicks it to the left.
    Is there a way to kick it to the right?  So when you are looking at the BOM it reads such that item 1 is in the first group and not the second.
    Best Regards,
    Scott McFadden
    (2 Corinthians 5:21)
    Please use plain text.
    *Expert Elite*
    Curtis_Waguespack
    Re: Parts List Wrapping Direction
    12-06-2012 12:14 PM in reply to: Cadmanto
    Hi Cadmanto,
    You can right-click on the parts list and choose Edit Parts List, then click the Table Layout button, then set the wrap direction. I don't recall a way to set this up in the Parts List style, but there might be one.
    I hope this helps.
    Curtis
      solution.png  Did you find this reply helpful ? If so please use the Accept as Solution or  Kudos button below.
    *Expert Elite*
    Cadmanto
    12-06-2012 12:44 PM in reply to: Curtis_Waguespack
    Thanks Curtis.
    That was almost too easy!!!  :smileyhappy:
    Best Regards,
    Scott McFadden
    Distinguished Contributor
    BLHDrafting
    12-06-2012 05:20 PM in reply to: Cadmanto
    There is also a radio button set when placing the parts list. See graphic.
    Brendan Henderson
    Web www.blh.com.au
    Twitter @BLHDrafting
    Windows 7 x64 -64 GB Ram, Intel Xeon E5-1620 @ 3.6 GHz
    ATI FirePro V7800 2 GB, 180 GB SSD & 1 TB HDD
    Inv R2013 PDS SP1.1 Update 2, Vault 2013 Workgroup Update 1
