• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Distinguished Contributor
    Part representation in drawing... can it be a symbol?
    257 Views, 12 Replies
    09-14-2012 11:25 AM
    Perhaps I'm confusing Substiute LOD's and some feature of the Punch representation?????
    I need to show column locations in a Plan (overhead) view.  The columns are so small that they don't show up very well.  Is there an "automagic" (I'd prefer not to have to manually place some kind of sketched symbol on each columns linework) way to do a PART REP (so-called) in a drawing?
    I'm using 2012 Premium.
    Thanks In Advance (TIA),
    John
    Please use plain text.
    *Pro
    jletcher
    Re: Part representation in drawing... can it be a symbol?
    09-14-2012 12:10 PM in reply to: jdavis417
    Not sure what you are asking do you  have a pic that I may get a better understanding?
    James Letcher
    2012 Factory Design Suite ( will not load 2013)
    What happen to my Inventor :-(
    09-14-2012 12:21 PM in reply to: jletcher
    Surely (huh, don't call you Shirley?)!
    Perhaps I've though of a few reasons why this might not be possible...???
    Such "substitution" in Plan view might work okay, but what about a Profile???
    Anywho, the attached image show the Sketched Symbol placed on the column linework to increase it's visibility.
    Thanks again,
    John
    *Pro
    jletcher
    09-14-2012 12:27 PM in reply to: jdavis417
    OK just so I am thinking right the red dots are the column in question correct?
    James Letcher
    09-14-2012 12:35 PM in reply to: jletcher
    In the words of Ed McMahon, "You are correct, sir. (hic)".
    :smileylol:
    *Pro
    jletcher
    09-14-2012 12:53 PM in reply to: jdavis417
    Well I have not found a way but this is what we do for a work around when I was doing buildings. I have a sketch that is in my master beam and in the IDW I show the sketch not the best way but a way that has worked for us.
    James Letcher
    10-04-2012 09:41 AM in reply to: jletcher
    James,
    Thanks again.  I've marked this as a "solution", but now am having difficulty getting the sketch to show in my drawings...
    it's "visible" in the part...
    What am I missing?  Any suggestions?
    thanks,
    John
    10-04-2012 09:49 AM in reply to: jdavis417
    jdavis417 wrote:
    ... but now am having difficulty getting the sketch to show in my drawings...
    This question has come up 3 times today.
    http://forums.autodesk.com/t5/Autodesk-Inventor/retrieve-a-bend-from-sweep/td-p/3646098
    very rare for it to come up at all.  What's going on today?
    *Pro
    jletcher
    10-04-2012 09:59 AM in reply to: jdavis417
    Just right click on the part in the browser show sketch. or you can change your select options  to parts and pick them from the view (faster) in view left click part then right click get sketches.
    James Letcher
    10-04-2012 11:50 AM in reply to: jletcher
    That's what I thought... that's what I tried... it works SOMETIMES.
    I'm in 2012.  Any idea why it's not consistent?
    Also, in JDMather's example he shows an "Enable" option when right-clicking on the (non-visible) sketch.  In the drawing environment, a sketch in a part does not EVER appear in the history browser for me.  What gives?
    Thanks to all,
    John
