• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Active Member
    Part configuratoin
    111 Views, 2 Replies
    11-19-2012 10:45 PM
    I want to ask if in Autodesk Inventor 2013, can we create a part with a different configuration??
    example:
    I made a cube the size of 10mm x 10mm x 10mm, after which it would be revised measures 15mm x 15mm x 15mm. The second revision to change the size of a 12mm x 12mm x 12mm.
    Can all the revision is done in one file?
    And if I want to revise again be 10mm x 10mm x 10mm, can?
    Have I been that provides revision always create a new file and the file number so much that hard to figure out which revision. Sorry, because I am still learning Autodesk Inventor 2013.
    thanks before,
    Please use plain text.
    *Pro
    Re: Part configuratoin
    11-20-2012 03:41 AM in reply to: 2shaen
    iParts allow you to create multiple versions of the same part, defined by values in a table.  Each of these, when placed in an assembly, actually creates a separate file for that size.  So, in your example, the iPart could define many different combinations of length, width and height, but only the ones that you have actually chosen to place in assemblies would be created as separate files.
    Is this what you are asking?  If I didn't understand properly, post again.
    *Expert Elite*
    Cadmanto
    11-20-2012 07:48 AM in reply to: 2shaen
    Like Sam said, creating iparts is the way to go.
    But understand once you have created them you need to generate them in order to get them
    to show effectively in your assemblies.
    Best Regards,
    Scott McFadden
    (2 Corinthians 5:21)
