• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Accepted Solution
    Part Lines in IDW
    163 Views, 4 Replies
    08-07-2012 01:44 PM
    I had a sketch in one of my views of a planned piece of equipment.  I hatched the equipment to show where it would be placed on my shaded views.  The part outlines behind the sketch were visible through the hatch.  I turned the visibility off of the part lines once I was finished with the sketch, everything is OK.
    Now that the proposed piece of equipment is no longer going to be used, I removed the sketch from the view, but my part lines are missing, making the view look a little odd. See below.  One side of my filter (gold part) has the outlines visible, the other side shows up without the lines.
    After removing visible lines, is there a way to turn them back on again??
    - Aaron -
    IV 2010 Tube & Pipe SP4; ACAD Mechanical 2010;
    2.5 ghz Xeon Processor
    8 gb RAM
    Windows 7 Professional x64
    EVGA GTX 560 2gb DDR5
    Please use plain text.
    *Pro
    jletcher
    Re: Part Lines in IDW
    08-07-2012 01:47 PM in reply to: doubleA26
    Yes there is right click in the view you should have an option to show hidden edges click on that then select the lines again like when you shut them off..
    James Letcher
    2012 Factory Design Suite ( will not load 2013)
    What happen to my Inventor :-(
    08-07-2012 01:49 PM in reply to: jletcher
    I never knew that....maybe should look at the RMB menu more often.  Kudos to you sir...
    - Aaron -
    8 gb RAM
    *Pro
    jletcher
    08-07-2012 01:54 PM in reply to: doubleA26
    Ahh shucks its nothin :smileytongue:
    James Letcher
    New Member
    BonnieWinchar7122
    08-08-2012 10:39 AM in reply to: doubleA26
    If I had known I could retrieve my lines back again, it would have saved me a ton of work over the last few years!   I never thought to question it, so thanks for asking the question in the first place and thanks to Mr. Fletcher for such a very simple solution.
