• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    New Member
    Pack and go - IAM
    129 Views, 2 Replies
    07-03-2012 01:28 AM
    Hi!
    Got a problem with my Pack n Go.
    Just wanted to copy an assembly by pack-and-go-ing it to another directory.
    Everythink looked fine, all files in the new folder.
    But when i opened the .iam file, several .ipt files are used from the old path
    Example:
    C:\AAA\Engine.iam
    Pack and go to:
    C:\BBB\
    If i open C:\BBB\Engine.iam my IPTs got the patch: C:\AAA\xyz.ipt.
    But of course I want the .IAM to use the files in C:\BBB\*.ipt
    Hopefully you understand my problem. Thx for helping!
    Please use plain text.
    Active Contributor
    danzco
    Re: Pack and go - IAM
    07-03-2012 07:26 AM in reply to: pi314
    Are any of those part files library files by chance?
    *Expert Elite*
    07-03-2012 01:03 PM in reply to: pi314
    Make sure you have switched to the new project to search the paths of your copied assembly and parts.
    If you are still in the original project opening your new assembly Inventor will look in the first paths and if it finds a correctly named part it will use it.
    Also as danzco stated if these parts are in libraries but were skipped at pack and go they will still be referencing the originals.
