• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Member
    PRESSURE LOADS IN AUTOCAD INVENTOR
    358 Views, 7 Replies
    11-02-2012 04:31 AM
    When adding pressure loads to a perpindicular face  inventor states that the pressure is applied uniformly to the selected face.
    As an example a disc of 300 mm dia(area= 70685 sq mm) with a uniform pressure load of 10MPa.
    The Question is this !
    Is the 10MPa load input  construed by inventor as 10MPa per square mm or 10MPa over the entire disc area.
    which is the correct interpretation?
    Please use plain text.
    Re: PRESSURE LOADS IN AUTOCAD INVENTOR
    11-02-2012 05:23 AM in reply to: methoni
    10MPa total over the area.
    Inventor Professional 2014 Edu 64-bit
    Member
    11-02-2012 05:40 AM in reply to: JDMather
    Thanks for the reply,if that is the case then i will have to rethink the plate thickness,the deflection seems awfully
    high.
    just for the record the input is as follows.
    Plate dia = 488mm
    thickness say 12 mm
    pressure on plate area 29 psi(0.199 Mpa)
    plate constraint on perimeter.
    material .mild steel
    analysis shows max displacement =0.48
    If you wish have a look.
    Regards
    methoni
    11-02-2012 05:57 AM in reply to: methoni
    oops, let me wake up a bit and look at this again.
    ...back in a while.
    In any case - it should be really easy to do a couple of virtual experiments to verify.
    Active Contributor
    11-02-2012 06:54 AM in reply to: methoni
    The answer is in your question.  What's a MPa?
    A MPa is 1,000,000 N/m² or 1 N/mm²
    which is an expression of pressure.
    IV 2013 Product Design Suite 64 Bit
    Win 7 64 bit
    Member
    11-02-2012 07:28 AM in reply to: rhinterhoeller
    Thanks for your input.
    What started out as a simple problem now seems to be confusing.
    So are you saying that if you enter a figure in inventor of say 10MPa,inventor knowing the surface area of plate(from original sketch input calculates the total load over the plate area.
    The deflection/stress is then derived from this extrapolation.
    Does this make sense ?
    Active Contributor
    11-02-2012 11:30 AM in reply to: methoni
    That makes sense.
    As JD suggested, experiment.  Try some simple exercises for which you can determine the results using classical methods until you're comfortable with the FEA interface.
    Win 7 64 bit
    blair
    11-03-2012 09:38 AM in reply to: methoni
    There is a difference between "Pressure" and a "Force" load in Inventor. A pressure load of 10 psi on a 12" x 12" plate will produce a total "load" of 1440 lb. A "Force" load of 10 lb on a 12" x 12" plate will produce a total "load" of 10 lb.
    The pressure load will always be acting perpendicular to the surface whereas a force load can be in any direction (vector) to the surface.
    The area that Inventor will use is dependent of the units used. If you are using Imperial and apply a 10psi, then the load force will be the 10 lb on every square inch.
    So a Pa is force of one Newton per square Meter and a MPa is 1,000,000 Pa
    IV2014.1 PDSU / Sim Mech 2014 /
    Win7-64
    EVGA X79 - Classified, iCore7 3930k 32Gb Quad-Channel
    950Gb (2 x 500Gb Sata III SSD RAID0 Adaptec 6805E Controller)
    Nvidia GTX-690 Classified - 320.18
    SpacePilot Pro 3.16.3 / 6.16.1 / 4.11
