• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Distinguished Contributor
    Accepted Solution
    Overlap flange in sheet metal
    196 Views, 3 Replies
    10-28-2012 08:44 AM
    I tried to create a overlap flange in sheet metal, but the result is not what I want as I cannot select the gap edge near the circle portion. Please help to check what is wrong? I attached the file here.
    Please use plain text.
    Active Contributor
    Re: Overlap flange in sheet metal
    10-28-2012 03:23 PM in reply to: lis_wang
    I believe it is giving the proper result. the first bend fot the overlap cannot start in a curved surface.
    M6400, FX3700M, 12GB, SSD
    Win 7 64
    Inventor 2013
    Employee
    10-28-2012 07:08 PM in reply to: lis_wang
    Currently the curve is not supported to be selected for flange. When the edge is selected for flange in this case, the linear edge is selected, and the curve is not selected. So the result from flange should be proper in this case.
    River Cai
    Quality Assurance Team
    Autodesk, Inc.
    10-28-2012 10:14 PM in reply to: Yijiang.Cai
    Thank you very much
