• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Autodesk Inventor
    *JGH
    Outlines printed shaded views in r6
    51 Views, 7 Replies
    10-30-2002 02:44 PM
    (same post was in the original inventor discussion, but its important for me
    to get this right. so I brought it here too)
    Noticed the prints (with shaded views) comes out looking more "cartoony"
    than in 5.3 ? The outlines are more defined with a bolder line than
    earlier. Same file in Inventor 5.3 looks normal...I use the same templates
    etc.
    Why, and how to get back to normal ? Please fix in Sp1 - I have allready
    sent away hundreds of drawings in r5.3 style, if I now send a revision done
    in r6 it don`t exactly "fit in" with the rest of the set if you see what I
    mean.
    Jørgen
    Please use plain text.
    *Yeandle, Laurence
    Re: Outlines printed shaded views in r6
    10-30-2002 05:21 PM in reply to: *JGH
    Jørgen, Try changing your visible edges in :- Format-Standards-Common, Drop
    the line weight.
    Laurence,
    "JGH" wrote in message
    news:C05B3FE57F27F476B2387858601D5789@in.WebX.maYIadrTaRb...
    me
    > etc.
    done
    > mean.
    > Jørgen
    *JGH
    Re:
    10-30-2002 05:32 PM in reply to: *JGH
    I want the lineweight on....
    "Laurence Yeandle" wrote in message
    news:F0641EE36FF4A8289BAC1D2F05B729C4@in.WebX.maYIadrTaRb...
    Drop
    > the line weight.
    > Laurence,
    for
    > me
    templates
    > > etc.
    > done
    I
    > > mean.
    > > Jørgen
    *Yeandle, Laurence
    Re:
    10-30-2002 07:55 PM in reply to: *JGH
    Sorry I meant drop the line weight down....... say from 0.5 to 0.35, this
    works fine for me. This should cut the cartoon's out to pro looking?
    Laurence,
    news:CF255ACD278C8E7D0CFFA585601AC574@in.WebX.maYIadrTaRb...
    > Drop
    > > the line weight.
    > > Laurence,
    > for
    > > me
    "cartoony"
    > templates
    > > > etc.
    allready
    > > done
    what
    > I
    > > > mean.
    > > > Jørgen
    *JGH
    Re:
    10-30-2002 09:49 PM in reply to: *JGH
    No good, I still want the 0.5 in hidden line views and the r5.3 shaded
    "style" had more like 0.25 than 0,35.
    I can`t change the lineweight down to that. I wan`t my drawings to look the
    same as they did in 5.3 without changing the standards....I guess this was a
    bug in 5.3 that is now fixed in r6 ? If so they should have made it a option
    instead.
    Jørgen
    news:59F697573040C3670A41833669A96C50@in.WebX.maYIadrTaRb...
    > Laurence,
    > > Drop
    > > > the line weight.
    > > > Laurence,
    important
    > > for
    > > > me
    > "cartoony"
    > > templates
    > > > > etc.
    > allready
    revision
    > > > done
    > what
    > > I
    > > > > mean.
    > > > > Jørgen
    *Rasmussen, Ed
    Re:
    10-30-2002 10:16 PM in reply to: *JGH
    I hope and believe that this will be addressed in a service pack. It
    certainly lowers the quality of the shaded views. I originally used very
    few shaded views, but have begun adding shaded isos to almost all my
    drawings the last few months. To diminish the value of this is not good.
    However, my greater immediate problem with the shaded views is the "bleed
    through" of lines that should be hidden. They do not show in my view until
    I print. Then apparently random lines pop up and make a mess of my printed
    view. I can individually select those lines and turn off visibility, but
    this is time consuming and difficult because the lines do not show in the
    view. Does anyone have a better work around for this? Do I need to
    eliminate the shading until this is fixed?
    Ed R
    news:E305B1F1697E1AADBB4FCD4E735B3CE3@in.WebX.maYIadrTaRb...
    the
    a
    option
    > instead.
    > Jørgen
    this
    > > Laurence,
    > > > Drop
    > > > > the line weight.
    > > > > Laurence,
    > important
    > > > for
    > > > > me
    > > "cartoony"
    than
    > > > templates
    > > > > > etc.
    > > allready
    > revision
    > > > > done
    see
    > > what
    > > > I
    > > > > > mean.
    > > > > > Jørgen
    *KJohnson
    Re:
    10-30-2002 11:53 PM in reply to: *JGH
    Can you save as BMP and then print the BMP to a pdf or to the printer. I
    had a similar problem in 5.3 and shaded presentations. The trails would
    bleed throught. I wonder if they still do?
    Kathy Johnson
    "Ed Rasmussen" wrote in message
    news:2111B32D493371B9E14D9C61B86E1464@in.WebX.maYIadrTaRb...
    until
    printed
    > Ed R
    > the
    was
    > a
    > option
    > > instead.
    > > Jørgen
    > this
    > > > Laurence,
    > > > > Drop
    > > > > > the line weight.
    > > > > > Laurence,
    > > important
    > > > > for
    > > > > > me
    > > > "cartoony"
    > than
    > > > > templates
    > > > > > > etc.
    > > > allready
    > > revision
    > > > > > done
    > see
    > > > what
    > > > > I
    > > > > > > mean.
    > > > > > > Jørgen
    *Rasmussen, Ed
    Re:
    10-31-2002 12:23 AM in reply to: *JGH
    I believe that can be done, but I use my shaded views on the same sheet with
    multiple non-shaded dimensioned views. Also, those BMP views would not
    update. Of course now that I think about it, the "cartoon" outline shaded
    views with "bleed through" need to be cleaned up all over again after a
    geometry change, so that may be an improvement in some cases. Certainly for
    presentation only, it could help. Thanks.
    Ed R
    "KJohnson" wrote in message
    news:FA5BC0A84A05E15DCF1560E6EAB02725@in.WebX.maYIadrTaRb...
    > Kathy Johnson
    very
    good.
    "bleed
    > until
    > printed
    but
    the
    > > Ed R
    look
    > > the
    > was
    > > a
    > > option
    > > > instead.
    > > > Jørgen
    > > this
    > > > > Laurence,
    > > > > > Drop
    > > > > > > the line weight.
    > > > > > > Laurence,
    > > > important
    > > > > > for
    > > > > > > me
    > > > > "cartoony"
    line
    > > than
    same
    > > > > > templates
    > > > > > > > etc.
    have
    > > > > allready
    > > > revision
    > > > > > > done
    you
    > > see
    > > > > what
    > > > > > I
    > > > > > > > mean.
    > > > > > > > Jørgen
