• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Member
    Accepted Solution
    Origin and line midpoints not turning green
    279 Views, 8 Replies
    05-21-2012 08:15 PM
    for some silly reason all of a sudden when i create a circle on the origin  it is not turning green and constraining the circle to it. Also when i am creating a line from the midpoint of another line the midpoint is not turning green and the line is not constrained to that point. Anybody have any ideas? I have checked the autoproject origin box in the appl settings and it is active.
    Please use plain text.
    *Expert Elite*
    blair
    Re: Origin and line midpoints not turning green
    05-21-2012 09:12 PM in reply to: mattfurches
    Check that your Constraint Persistants and Constraint Inferance have not been turned off. Enter Sketch mode, from the Constraint drop-down menu make sure that they are selected.
    IV2014.1 PDSU / Sim Mech 2014 /
    Win7-64
    EVGA X79 - Classified, iCore7 3930k 32Gb Quad-Channel
    950Gb (2 x 500Gb Sata III SSD RAID0 Adaptec 6805E Controller)
    Nvidia GTX-690 Classified - 314.07
    SpacePilot Pro 3.16.1 / 6.16.0 / 4.11
    Member
    05-22-2012 04:44 AM in reply to: blair
    i have checked the persistence and it is on. Anybody else?
    Employee
    05-22-2012 05:03 AM in reply to: mattfurches
    In the same "Constrain" pull-down, click Constraint Options and verify that coincident and midpoint are checked.
    Patrick Miller
    Senior Content Developer
    Autodesk, Inc.
    Member
    05-22-2012 05:11 AM in reply to: patrick.miller
    In my constrain drop down box i dont have an options button.
    *Expert Elite*
    05-22-2012 05:13 AM in reply to: mattfurches
    While in sketch environment right click in the graphics window and select Constraint Options.
    trumpy81
    05-22-2012 05:21 AM in reply to: mattfurches
    Does the attached image help?
    I have been having similar problems, but it is quite random and only seems to happen at certain zoom levels. Sometimes I'm able to attach to the midpoints etc... as per normal, and sometimes the mouse becomes a little erratic and I cannot always select the point or line directly.
    Although the points usually do show and change color as expected.
    Regards
    Andy M
    Autodesk Inventor 2013 Pro SP1.1, Win7 Pro - 64Bit - SP1, Intel i7 960 @ 3.333 GHz
    Asus X58 Sabertooth, Corsair 12Gig DDR3, AMD Radeon HD6970, Samsung 830 Series 256G SSD, 2x 3TB Seagate, 2x 2TB Hitachi,
    1x 1TB Samsung, 4 x 2TB Seagate in Netgear ReadyNAS NV+, Dual Asus VE278Q Monitors
    Member
    05-22-2012 10:07 AM in reply to: trumpy81
    it was the contraint options. for some unknown reason all the options had become unchecked. thanks for the help.
    Member
    11-16-2012 02:00 AM in reply to: mattfurches
    right click --->constraint options ---->select all ----->apply.
