• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Autodesk Inventor
    *Reeners, Ed
    Opening DWG file crashes Inventor
    60 Views, 3 Replies
    11-18-2002 10:33 PM
    I have tried this on two computers with the same results Both machines are
    PIII 650, running Windows XP Pro SP1, and Inventor 6.0 SP1.
    In Inventor
    File > Open
    For the file type select DWG, and then select OPTIONS
    This brings up the "Drawing File Import Options" screen. Use the default
    settings, and then click NEXT.
    On the "Layer and Object Import Options" screen use the default settings,
    On the "Import Destinations Options" Screen go down to the bottom of the
    screen and select ADVANCED OPTIONS.
    Click on the FONT TAB, and Inventor crashes
    Please use plain text.
    *Jason
    Re: Opening DWG file crashes Inventor
    11-18-2002 10:53 PM in reply to: *Reeners, Ed
    i've run into the same problem on two computers.
    i have also posted this question on autodesk support request, but they could
    not duplicate the problem.
    the following is their solution which i have just completed but it didn't
    work.
    I think there may be an improper registry entry for VoloView that may the
    reason for crash.
    Please do the following:
    1. Uninstall Inventor 6 and Volo View Express using the Add/Remove Programs.
    2. Reboot.
    3. Delete the install folder (default C:\Program Files\Autodesk\Inventor 6
    4. Edit the registry and delete the two Inventor 6 folders, Found at:
    HKEY_CURRENT_USER\Software\Autodesk\Inventor &
    HKEY_LOCAL_MACHINE\SOFTWARE\Autodesk\Inventor.
    5. Reboot the machine and log in in VGA mode
    6. Install Inventor 6, volo view in VGA mode.
    "Ed Reeners" wrote in message
    news:B44E4D04BF5BFBC0027BDEC2870A3623@in.WebX.maYIadrTaRb...
    > In Inventor
    > File > Open
    *Reeners, Ed
    11-18-2002 11:04 PM in reply to: *Reeners, Ed
    Thanks!
    I will give this a try.
    > In Inventor
    > File > Open
    *Jason
    Re:
    11-18-2002 11:08 PM in reply to: *Reeners, Ed
    don't bother, after all that, it still doesn't work.
    news:04767FFAE228DC457A24918B655EF6ED@in.WebX.maYIadrTaRb...
    > Thanks!
    are
    > > In Inventor
    > > File > Open
    settings,
