Autodesk Inventor
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
Open a Solidworks file as a sheet metal part in Inventor 2011
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Hi all,
I have a Solidworks file that is a sheet metal part in Solidworks...
I need to know how to open this file in Inventor so that I can access the features (eg. Flange, Hole, etc.) in Inventor.
We are recieving the Solidworks file from a design firm and once our work with them is done, we need to be able to edit the file ourselves.
I am open to all suggestions.
Re: Open a Solidworks file as a sheet metal part in Inventor 2011
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
File>Open files of type *.sldprt
Set the sheet metal style to correct thickness.
Edit the features that are incorrect and therefore need editing.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
you might be able to use this to get some of the features in:
http://labs.autodesk.com/utilities/feature_recogni
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
@ JDMather
The problem is that when I open the Solidworks file there are no features to edit...even after setting the thickness.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
@ B Miller63
That is a nice addon, but it only works for solid models that are not sheet metal parts.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
onebigfellah wrote:@ JDMather
I can edit parts with no feature tree (of course there are still features - even without a history tree) without significant issue. What problem are you experiencing in editng parts?
Even SolidWorks does not preserve a history tree going backwards - but is it still possible to edit the part without a history tree in SWx as well.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
How do you change the bend radius on a flange in Inventor when the file doesn't have any features to edit?
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Three choices:
1. brute force.
make a cut to remove the existing bend from the solid body. extend the cut to match the ends of the new radius. Make an extrusion with the new radius to suit.
2. Inventor Fusion may help. See Autodesk Labs
3 Buy Solidworks
Next time make sure that your subcontractors use the same CAD package as you.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
onebigfellah wrote:How do you change the bend radius on a flange in Inventor when the file doesn't have any features to edit?
...or #4 The Easy Way
Delete Face with Heal
Bend
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I am currently downloading Fusion and I will be giving that a try shortly.
I'll let you guys know what comes of it.
Otherwise, I will be entertaining some of the other ideas you gents posted.
