Autodesk Inventor
Topic Options
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
Object appears of the ground when an image is inserted ? Shadow and Reflection
Options
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
78 Views, 1 Replies
02-12-2012 10:49 AM
Hi All,
I hope you can help. When I add an image to my sketch the main body then appears "of the ground" as you van see from the attached screen shot. The shadow and reflection is distant. The minute I remove the instead image the object and the shadow touch again as it should be... I'm puzzled.
Can anyone help ?
Kev
Re: Object appears of the ground when an image is inserted ? Shadow and Reflecti
Options
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
02-12-2012 01:01 PM in reply to:
wiptheman
I found the solution so I'll post the reply > Using the Decal function to attache the image to the object will eliminate the problem.
Ribbon: Model tab Create panel Decal
