• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Product Support
    Re: O-Ring Generator Only Showing One Size, regardless of type?
    07-27-2012 06:36 AM in reply to: tdswanson
    It is the same for all standards, you can only pick one o-ring, you change the size dynamically.
    I agree it is a little tricky but possible. It will cut the groove for you.
    Give it a try.
    Jon
    Jon Dean
    Support Specialist
    Product Support
    Autodesk, Inc.
    Please use plain text.
    Valued Contributor
    07-27-2012 06:48 AM in reply to: jon.dean
    Yes, I've experimented now and found this to be true.  It's a little strange to have the list available to you and not be able to use it at all.
    When I was trying to do this, I was creating a seal on a fairly large diameter, so I was zoomed out quite a ways.  So the little tiny oring comes in and the glyphs are so small that I wouldn't have thought to zoom way in and have to drag it all the way out.
    Nonetheless, I'm glad to have the issue resolved.
    Any provisions coming up for dovetail and/or half-dovetail grooves?  Turns out, I rarely ever use a "regular" groove because we need the seal retention provided by the dovetail.
    Thank you all for your help!
    Inventor 2013 64-bit SP1.1, single user
    Win 7 Pro 64-bit SP1
    Product Support
    07-30-2012 06:39 AM in reply to: tdswanson
    I think over the last couple of releases we have not seen a lot of change in the O-Ring section of the Design Acceleerators. I can open a Wish on your behalf, hopefully development will review the wish.
    Jon
    Jon Dean
    Support Specialist
    Product Support
    Autodesk, Inc.
    sgold
    12-12-2012 09:08 AM in reply to: jon.dean
    I just messed with this for the first time.  I wouldn't consider it goofy, it downright SUCKS to drag the handles.  If I actually had some control over the handles it would be great to size as you drag, but I could never get it to just stop on the dimension I wanted without lots of trial and error.  Have both capabilities would be good, drag handles or specify from a list of all available sizes.  So enhancement (more like fix it) would be nice for the axial selection.
    --Scott
    Scott G.
    Using Inventor 2013 and Vault Basic (New to Inventor)
    6 years Solidworks (v2006-2010)
    10 years Pro-Engineer (v13-WF2) w/ Intralink (2.0-3.0)
    2 years of Mechanical Desktop
    AutoCAD since R12
    First professional CAD: DrafixCAD
    sgold
    12-12-2012 10:08 AM in reply to: sgold
    AH, here's an improvment.  Doesn't tell you, but you can double click the drag arrow to select a size from the drop down, and it looks like the drop down provides all available sizes!
    --Scott
    Scott G.
    AutoCAD since R12
