Autodesk Inventor
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Printer Friendly Page
Re: O-Ring Generator Only Showing One Size, regardless of type?
- Highlight
- Email to a Friend
It is the same for all standards, you can only pick one o-ring, you change the size dynamically.
I agree it is a little tricky but possible. It will cut the groove for you.
Give it a try.
Jon
Jon Dean
Support Specialist
Product Support
Autodesk, Inc.
- Highlight
- Email to a Friend
Yes, I've experimented now and found this to be true. It's a little strange to have the list available to you and not be able to use it at all.
When I was trying to do this, I was creating a seal on a fairly large diameter, so I was zoomed out quite a ways. So the little tiny oring comes in and the glyphs are so small that I wouldn't have thought to zoom way in and have to drag it all the way out.
Nonetheless, I'm glad to have the issue resolved.
Any provisions coming up for dovetail and/or half-dovetail grooves? Turns out, I rarely ever use a "regular" groove because we need the seal retention provided by the dovetail.
Thank you all for your help!
Inventor 2013 64-bit SP1.1, single user
Win 7 Pro 64-bit SP1
- Highlight
- Email to a Friend
I think over the last couple of releases we have not seen a lot of change in the O-Ring section of the Design Acceleerators. I can open a Wish on your behalf, hopefully development will review the wish.
Jon
Jon Dean
Support Specialist
Product Support
Autodesk, Inc.
- Highlight
- Email to a Friend
I just messed with this for the first time. I wouldn't consider it goofy, it downright SUCKS to drag the handles. If I actually had some control over the handles it would be great to size as you drag, but I could never get it to just stop on the dimension I wanted without lots of trial and error. Have both capabilities would be good, drag handles or specify from a list of all available sizes. So enhancement (more like fix it) would be nice for the axial selection.
--Scott
Using Inventor 2013 and Vault Basic (New to Inventor)
6 years Solidworks (v2006-2010)
10 years Pro-Engineer (v13-WF2) w/ Intralink (2.0-3.0)
2 years of Mechanical Desktop
AutoCAD since R12
First professional CAD: DrafixCAD
- Highlight
- Email to a Friend
AH, here's an improvment. Doesn't tell you, but you can double click the drag arrow to select a size from the drop down, and it looks like the drop down provides all available sizes!
--Scott
AutoCAD since R12
