• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    ihiengdept
    No text shows using hole annotation tool in inventor 2011
    372 Views, 3 Replies
    01-17-2011 02:47 PM
    I'm using inventor 2011.  I'm creating a drawing for a part, and when I attempt to annotate a hole, no text shows up.  Just a blank leader line.  The hole is a thru hole, but when I change it to another type, (like "distance" or "to") it will give me the text.  So what am I missing?  I've made other parts where I don't have this issue, but nothing works recently.
    Please use plain text.
    Valued Mentor
    jeanchile
    Re: No text shows using hole annotation tool in inventor 2011
    01-17-2011 08:37 PM in reply to: ihiengdept
    This may be a stupid question but I'm gonna' ask it anyway: Have you looked at your style library to make sure the note for a thru hole hasn't been edited/deleted? I've never encountered this issue, it's just the first thing I though of.
    Inventor Professional 2013 (SP-1.1), Product Design Suite Ultimate
    Desktop: Intel Core i7 3.4GHz, 16.0 GB RAM, Windows 7 Ultimate SP-1, 64-bit OS, (2) GeForce GTX 580 (314.07), Space Pilot Pro (3.16.1)
    Laptop: Intel Core 2 Duo T9600 @ 2.8GHz, 8.0 GB RAM, Windows 7 Pro SP-1, 64-bit OS, GeForce GTS 160M (314.07), SpaceNavigator (3.16.1)
    *Pro
    01-18-2011 05:01 AM in reply to: ihiengdept
    When you edit the blank thru hole note, what do you see?  You should see something like this:
    <QTYNOTE>Ø<HDIA> THRU.  If not, your style library and/or template needs some remediation...
    ihiengdept
    04-20-2011 05:32 AM in reply to: sbixler
    Things got busy and it took me a while to get back this, but both replys were right on.  Somehow that one definiton for a THRU hole got completely deleted in the style library for a template I was using.  I'm still fairly new to autodesk so I really appreciate the help.
    Thanks!
