• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Valued Contributor
    eric.mathews
    No Vault Tool bar 2013.
    249 Views, 1 Replies
    10-19-2012 06:47 AM
    I recently installed Vault pro 2013. I was running Inventor 2012 at the time.. My vault add-in stopped loading. I installed Inventor 2013 and the vault add-in still won't load. I've gone to the Add-in manager 2013 and set it to loaded. I hit the "OK" button and nothing. Open the manager up again and it says "unloaded". Something is going on that is not allowing my vault add-in to load. This is very frustrating. Any suggestions?
    Please use plain text.
    Product Support
    Re: No Vault Tool bar 2013.
    10-22-2012 06:20 AM in reply to: eric.mathews
    Have you tried changing the Vault Client from Programs and Features?
    1. Right click on the Vault Client and select Change.
    2. Now select Add / Remove Features.
    3. Un-check the Add-in for Inventor.
    4. Update.
    5. Now go back and this time check the option to add the Add-in.
    6. Update.
    Hopefully this should work OK.
    Jon.
    Jon Dean
    Support Specialist
    Product Support
