• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Autodesk Inventor
    *Howard, Jeff
    No RTTI data....
    192 Views, 9 Replies
    11-14-2002 07:15 AM
    crash. See CF "No RTTI data (IV6).
    Initiate loft command.
    Pick profiles: sketches 11, 12, 15.
    Pick rails: sketches 13, 16, 14
    Go to Transitions tab and clear Automatic checkbox.
    Crashed 5 out of 6 times for me. Also crashed in the original file the
    sketches were derived from.
    Jeff
    Please use plain text.
    *Caldwell, Larry
    Re: No RTTI data....
    11-14-2002 07:53 AM in reply to: *Howard, Jeff
    Jeff, need the parent file to go with the derived part. It is looking for
    Surfaces U & V when I try to open it and yours is different than mine.
    ~Larry
    "Jeff Howard" wrote in message
    news:9F96604BC4BA45504E67C14EE9B691C6@in.WebX.maYIadrTaRb...
    > Jeff
    *Howard, Jeff
    Re:
    11-14-2002 01:30 PM in reply to: *Howard, Jeff
    You should be able to put my file in a directory or project where it can't
    find your version of Surfaces U & V and Skip All when loading it (at least
    that's what I did, should have broken the link before sending). My file will
    look slightly different than your original, I'd made some small changes and
    projected geometry to create the new rail sketches.
    Interested to see if it's reproducible or just my system being cantankerous.
    "Larry Caldwell" wrote in message
    news:257ED1F82099A0BA231B961BB3CA162E@in.WebX.maYIadrTaRb...
    ~Larry
    > Jeff
    *Yeandle, Laurence
    Re:
    11-14-2002 05:37 PM in reply to: *Howard, Jeff
    Hi Jeff, crashes here too, don't now anything about surfaces other than
    looking at your stuff. The model solves quite easily if you loft from 12 to
    11 and 11 to 15 using two lofts, the inclusion of the rails in lofts does
    nothing it appears and trying to loft three sketches at once fails without
    the rails as well. You can use the rails on loft 11 & 12 OK but rails on the
    11 & 15 fails. I would have thought that the rails were not needed at all
    seeing that the shapes are similar? And failure of 11 & 15 with rails might
    be due to the orientation of the sketches at 90o ? But what do I Know,
    Autodesk will no doubt shed some light.
    Laurence,
    Power is nothing without Control
    news:6C928D0B4867B80953C703658626C3E0@in.WebX.maYIadrTaRb...
    will
    and
    cantankerous.
    > ~Larry
    > > Jeff
    *Howard, Jeff
    Re:
    11-14-2002 07:04 PM in reply to: *Howard, Jeff
    Thanks for looking, Laurence.
    The sketches are from Larry's file related to the Shape Manager Unmanagable
    thread, where Larry and I demonstrated how little we know about the subject
    8~). I was playing with it when IV so rudely dumped me on the roadside.
    Have a good one,
    Jeff
    "Laurence Yeandle" wrote in message
    news:3B6EBAC3D6FE8B900BF7D74B639C940F@in.WebX.maYIadrTaRb...
    Hi Jeff, crashes here too,.......
    *Yeandle, Laurence
    Re:
    11-14-2002 08:56 PM in reply to: *Howard, Jeff
    Oh if I'd have known it was one of Larry's fumble's I wouldn't have bothered
    I suppose that loft is the only chance of some sort of compound curve
    you wish to get on the stern of the tub, I need to look into this in 6.0 and
    how it controls shapes. From what I gather 5.3 points were to control twist
    in model, are you trying to control the curve of (contour path ) on hull to
    give a realistic shape is that what rails are supposed to do? I feel that
    compound surfaces in IV will remain illusive still or can this be done or
    will any package handle this, similar to a 3d sweep?
    Laurence,
    news:613938EA3C81BE7D94CC56F0F1EA442D@in.WebX.maYIadrTaRb...
    Unmanagable
    subject
    > Have a good one,
    > Jeff
    *Caldwell, Larry
    11-14-2002 08:58 PM in reply to: *Howard, Jeff
    Yep ... no rtti-ditti ... just like you. Won't even give you a chance to try
    to change it. I saw a post saying what RTTI meant but can't find it. I don't
    think the post had the acronym, just the words so that's probably why a
    message search on RTTI doesn't turn it up. Maybe someone remembers.
    ~Larry
    > Jeff
    *Caldwell, Larry
    Re:
    11-14-2002 09:22 PM in reply to: *Howard, Jeff
    Ah ... but now you know!
    ~Larry
    news:A687E1E52E058DB62E5A224B1E82B581@in.WebX.maYIadrTaRb...
    bothered
    curve
    and
    twist
    to
    > Laurence,
    > Unmanagable
    > subject
    > > Have a good one,
    > > Jeff
    *Autodesk\
    11-15-2002 03:27 AM in reply to: *Howard, Jeff
    I logged a defect against it.
    Loren Jahraus
    Autodesk Inventor Workflow Team
    > Jeff
    *Howard, Jeff
    Re:
    11-15-2002 04:45 AM in reply to: *Howard, Jeff
    Many thanks, Loren.
    "Loren Jahraus (Autodesk)" wrote in message
    news:502669F952FE61610BB7BE042215EC85@in.WebX.maYIadrTaRb...
    Loren Jahraus
