No Countinuous wall thickness with Shell command
I have a blade housing that requires a continuos radius around the profile. It is not a full radius. When I shell the blade, it looks like the raidius wants to continue. I was told I had to use two fillets and the particial radius will not work. However, the continuous radious in the customers requirement. Is there a way to shell this part correctly?
The shell is working correctly.  You're leaving an edge with that sweep.  (As shown in first attachment).  Your gemoetry in Sketch3 is to blame.  (See second attachment).
Yes, I see my sweep mistake. That makes more sense. Thank you Michael.
Sue
