• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Valued Contributor
    New to Inventor 2013
    340 Views, 12 Replies
    10-11-2012 07:34 AM
    Howdy Yall,
       My company, which currently works in ONLY AutoCAD 2D (!), is in the midst of a transition to 3D. We are evaluating both SolidWorks and Inventor. 2013 of both pieces of software. My backgtound is with SolidWorks, Solid Edge, and a little Unigraphics. This isn't a thread to start a "which is better" argument as I understand they both have their strengths and weaknesses. However, coming from a "SolidWorks mindset", maybe there are a few things yall can help me figure out in Inventor.
       Simple offset. I often do a sketch in 2D to extrude to 3D and use the offset command. How come it doesn't allow direct input for offset distance? It seems instead of choosing offset then selecting the curve, typing a distance, and clicking a side/direction, I have to arbitrarily offset the curve then go back and dimension it with another tool. This seems very inefficient to me?
       I do a lot of sheet metal modeling. In SolidWorks I might make a profile sketch of a square tube, for example, then convert it to sheet metal by selecting a base, bend edges, and giving them bend radii and whatnot. Seems very intuitive to me. I haven't found a similar method of doing that in Inventor. It seems I have to draw and extrude only one side then keep creating flanges for the remaining sides. That isn't a problem when creating a sheetmetal part from the get go, but how about converting? I can convert a part to sheet metal but it doesn't bend my edges visibly nor do I think it adds any extra material to the bends in the flat pattern.
       And very basic...how do I re-orient a single 3D part? For example if I click on the front plane on the "viewing cube" in the upper right, maybe it turns to the right side of my part. I know it's a mistake with how I originally created it, but can I re-orient it so that when I make drawings, the front is actually what I consider the front?
       Also, is there any easy way to center a line on an axis/origin? For example, in a 2D sketch say I draw a rectangle. I want this rectangle to stay completely centered about the origin, regardless of what dimensions I put on it. For now, I dimension the rectangle, then manually divide the dimensions by two and dimension that to the origin. It adds an extra few steps when I change the dimensions of the rectangle. This question applies to all shapes, not just rectangles.
    Thanks yall!
    Please use plain text.
    *Expert Elite*
    Re: New to Inventor 2013
    10-11-2012 07:43 AM in reply to: drguitarum2005
    Start here
    http://home.pct.edu/~jmather/skillsusa%20university.pdf
    Why you are working through that someone will come and answer your questions.
    I recommend you post example files too.
    *Expert Elite*
    10-11-2012 07:49 AM in reply to: drguitarum2005
    drguitarum2005 wrote:
       I do a lot of sheet metal modeling. .
    Thanks yall!
    Inventor sheet metal is far better than SolidWorks.
    Add bends
    or better yet
    use the sheet metal tools in the first place.
    Converting isn't so bad - just different than SWx
    Attach example files here.
    *Expert Elite*
    10-11-2012 07:53 AM in reply to: JDMather
    As far as Offset -
    I saw Cob Rohee of Autodesk state, "We heard you" on this issue two years ago at AU, and for some reason I thought it had been fixed, but just tried in 2013 and I couldn't get it to work.
    Valued Contributor
    10-11-2012 08:27 AM in reply to: JDMather
    Thank you for all the quick replies! Re-orienting the view seems easy enough, I wish I had thought about right clicking on that cube...
    The offset thing I can deal with, it's not too big of a deal.
    Are there any good sheet metal tutorials for how to create it "right" the first time? I still haven't figured out how to set bend edges when converting to sheet metal instead of making it from sheet metal to start.
    Thanks again
    *Expert Elite*
    10-11-2012 08:42 AM in reply to: drguitarum2005
    I haven't seen anything good in years and haven't had time to write much myself.
    Fastest way to show some solutions might be for you to attach some example files here.
    I have some that I will attach later today if I get a chance.
    If you still have access to SolidWorks I have some equivalent sldprt and ipt sheetmetal files to show how to transition techniques from one to the other program.
    Valued Contributor
    JohnK_TEDCF
    10-11-2012 08:46 AM in reply to: drguitarum2005
    My company offers training for Inventor and SolidWorks.  We have an Inventor course that deals with Sheet Metal.  If you would like more information, let me know.
    John Koop
    Software Engineer/ Inventor Specialist
    TEDCF Publishing
    www.trainingtutorial.com
    *Expert Elite*
    10-11-2012 09:11 AM in reply to: JohnK_TEDCF
    well as long as we are advertising here
    ditto
    http://www.pct.edu/wdce/
    :smileysurprised:
    Valued Contributor
    JohnK_TEDCF
    10-11-2012 09:29 AM in reply to: JDMather
    I have to agree with you on the Inventor Sheet Metal environment JD. We are currently working on adding a Sheet Metal course for SolidWorks, and so far Inventor seems to be a much better choice in this aspect.
    John Koop
    TEDCF Publishing
    *Expert Elite*
    10-11-2012 09:38 AM in reply to: JohnK_TEDCF
    There are a couple of things I like in SWx sheet metal that Inventor doesn't have (at least not directly), but I was kind of surprised how much difference there is (I haven't seen SWx 22013).
