• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    *Shang, Thomas
    New Field creation in revision box and Holechart
    64 Views, 1 Replies
    11-07-2002 10:59 AM
    I just start to use IV6. I am wondering for so called improved Holechart and
    revision feature in idw, after adding new field as additional column, how to
    input value? I guess this shall be similar to what it is in partlist --
    create a custom property with the same name as new field. I've tried with no
    avail. I am sure I missed something, but what? Should autodesk have done
    this the same as partlist?
    In addition, how to input value for "Description" column which comes as
    default --" value" for revision box? I've tried "Description" from both ipt
    and idw property.
    In the first place, it was claimed by autodesk that holechart has much
    improved. I presume this is going to be the same as in AutoCAD Mechanical.
    In fact, it's not. Even worse, it still inherit nasty stuff from 5.3, like
    the line spacing is too wide for couterbore hole note. Any way to adjust it.
    Anyone sheds some light on me?
    Please use plain text.
    *Cleveland, Dave
    Re: New Field creation in revision box and Holechart
    11-07-2002 02:40 PM in reply to: *Shang, Thomas
    You can edit the text in your additional column by double clicking directly
    on the text. You should get an edit box.
    One serious shortcoming I've found with the custom columns: In one of my
    tables I needed some notes for a few holes and nothing for others. To get
    an empty field, I entered a space. Lately, I have tried to go back and add
    text in some of the null fields but there is nothing to select, and
    therefore no way to put text back in.
    There also may be a bug in the text justification of the LOC column. I have
    tried to set the justification to "center" or "right" but it remains nailed
    to the left.
    I have not found any way to edit the text in the default columns.
