• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Active Contributor
    jonathanruffray
    Network license & Options bug
    75 Views, 1 Replies
    02-04-2013 09:34 AM
    Hello all,
    We had experiencing an irritating bug with Inventor 2012 and it has not been corrected in the 2013 version... and maybe some of us have this trouble without catching it... this trouble is a little bit vicious:smileysad: I will explain me.
    We use network (floating) licensing registration and sometimes there is too much resquest than license and the server refuse the access to Inventor... Until there all goes well. But when you get the license after that, the application options have changed in Inventor !! :smileyfrustrated:
    It could be the sketch option, the drawing...  But it could be the CC configuration... And if you use Vault server (As us), your configuration could go back to local CC instead of Vault !!!  And if you're not aware with that... what a pain to replace the hundreds of screws, whashers... from the local CC to the Vault CC...:smileysad:
    Autodesk people, please fixed it ...
    John.
    Autodesk Product Design Suite Ultimate 2013
    Win 7 Pro 64 bits SP1
    Bi-Xeon E5520 (2x Quad-core @2.27GHz)
    Quadro Fx 1800 768Mo GDDR3
    6Go Ram DDR3 667MHz ECC
    Please use plain text.
    Product Support
    Daniela_Koloszko
    Re: Network license & Options bug
    02-06-2013 01:41 AM in reply to: jonathanruffray
    This issue has been reported to us and we have change request logged with development about Application settings being reset after being denied a license. They are working currently to fix the problem.
    A workaround for the moment is to save the customization to a xml file and import it in Inventor when the problem reoccurs.
    Daniela Koloszko
    Product Support Specialist
    Autodesk Product Support
    MFG
