• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Autodesk Inventor
    *Dickerson, Jeff
    Need help with creating a Part
    56 Views, 14 Replies
    10-02-2003 01:57 AM
    Ok. Not sure how to do this. It is plastic (poly-pro), characteristics of
    pipe (cylinder with a wall thickness) and has a punch thru pattern of
    squares. It is a guard for our product, length differs. How do I get the
    pattern of punch outs? Am I making sense?
    Please use plain text.
    *Dickerson, Jeff
    Re: Need help with creating a Part
    10-02-2003 02:06 AM in reply to: *Dickerson, Jeff
    *Dotson, Sean
    Re:
    10-02-2003 02:09 AM in reply to: *Dickerson, Jeff
    Why not model the cylinder and use a transparent texture (like the expanded
    metal) to simulate the mesh.
    Or do you need to have all of those holes as features?
    Sean Dotson, PE
    http://www.sdotson.com
    Check the Inventor FAQ for most common questions
    www.sdotson.com/faq.html
    "Jeff Dickerson" wrote in message
    news:f18f963.0@WebX.maYIadrTaRb...
    *Dickerson, Jeff
    Re:
    10-02-2003 02:11 AM in reply to: *Dickerson, Jeff
    Actually I do not NEED the wholes. It is for a brochure. It just needs to
    look like it. I am not sure how to mesh...I will seek help in the help file
    and if I can not fiqure out I'll post so.
    Thanks Sean.
    *Dickerson, Jeff
    Re:
    10-02-2003 02:15 AM in reply to: *Dickerson, Jeff
    Awesome...Thanks...
    *Jacquemotte, Dave
    Re:
    10-02-2003 02:16 AM in reply to: *Dickerson, Jeff
    He thinks the Help File will help....
    in disbelief>
    Dave Jacquemotte
    Automation Designer
    www.autoconcorp.com
    news:043862EADF0F50C6267A1475C1563264@in.WebX.maYIadrTaRb...
    > Thanks Sean.
    *Bible, John E.
    Re:
    10-02-2003 02:31 AM in reply to: *Dickerson, Jeff
    Sean, enlighten me almighty texture wizard. I have looked under colors and
    materials and I cannot find the expanded metal selection. I have a guard to
    make where this would fit just perfect. Please elaborate.
    John
    "Sean Dotson" wrote in message
    news:F3E3D9479C97AF1BEABCDF2A55AE7E82@in.WebX.maYIadrTaRb...
    expanded
    > Sean Dotson, PE
    *Keller, Kent
    Re:
    10-02-2003 02:41 AM in reply to: *Dickerson, Jeff
    Format >> colors >> Texture tab >>
    Pick the color you want to use , then use the Choose button the pick the texture for it
    Then just hit apply.
    Kent
    Assistant Moderator
    Autodesk Discussion Forum Moderator Program
    "John E. Bible" wrote in message
    news:0CF0C5C8B9C26699E3E64CF151E785C8@in.WebX.maYIadrTaRb...
    > Thanks
    *Zander, Quinn
    Re:
    John,
    This is what a texture can do for you.
    I will post the part and with the texture in iCF.
    QBZ
    colors and
    guard to
    *Dotson, Sean
    Re:
    I see my CAD minions have answered your question
    Sean Dotson, PE
    "Quinn Zander" wrote in message
    news:15DAE82ED22D33F9277225C550F50894@in.WebX.maYIadrTaRb...
    > John,
    > QBZ
    > colors and
    > guard to
