• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    New Member
    Need help with VB editor code within Inventor Please?
    70 Views, 0 Replies
    11-02-2012 09:06 AM
    I am trying to run a piece of code in the VB editor to make it loop through each page of an Excel workbook, but for the reason that I am no VB expert I cannot get it to work, can anyone please help me. I have pasted the code below, I feel that someone with good VB knowledge could solve this in a minute or two. Many Thanks
    Option Explicit
    Private oExcel As Excel.Application
    Private oSheet As Excel.WorkSheet
    Private oPartDoc As PartDocument
    Private Sub CloseSpline_Click()
    End Sub
    Private Sub ColumnX_Change()
    End Sub
    Private Sub ColumnZ_Change()
    End Sub
    Private Sub UserForm_Initialize()
    Set oPartDoc = ThisApplication.ActiveDocument
    Set oExcel = GetObject(, "Excel.Application")
    Set oSheet = oExcel.ActiveSheet
    End Sub
    Private Sub UserForm_Terminate()
    Set oPartDoc = Nothing
    Set oExcel = Nothing
    Set oSheet = Nothing
    End Sub
    Private Sub Create3DSpline_Click()
    If Create3DSpline.Value = True Then
    Createpolyline.Value = False
    CloseSpline.Enabled = True
    Else
    CloseSpline.Enabled = False
    Createpolyline.Value = True
    End If
    End Sub
    Private Sub CreatePolyline_Click()
    If Createpolyline.Value = True Then
    Create3DSpline.Value = False
    Closepolyline.Enabled = True
    Else
    Closepolyline.Enabled = False
    End If
    End Sub
    Private Sub OKButton_Click()
    Dim j As Integer
    Dim xSheet As String
    For j = 1 To 10
    Dim bCreateSpline As Boolean
    Dim bCreatePolyline As Boolean
    bCreateSpline = Create3DSpline.Value
    bCreatePolyline = Createpolyline.Value
    Dim bCloseSpline As Boolean
    bCloseSpline = CloseSpline.Value
    Dim bClosePolyline As Boolean
    bClosePolyline = Closepolyline.Value
    ThisApplication.UserInterfaceManager.UserInteractionDisabled = True
    Dim oDef As PartComponentDefinition
    Set oDef = oPartDoc.ComponentDefinition
    Dim oPoints As ObjectCollection
    Set oPoints = ThisApplication.TransientObjects.CreateObjectCollection
    Dim oUsedRange As Range
    Set oUsedRange = oSheet.UsedRange
    Dim oRowCount As Long
    oRowCount = oSheet.Range("A65536").End(xlUp).Row
    Dim i As Integer
    For i = 1 To oRowCount
    Dim strx As String, stry As String, strz As String
    strx = oUsedRange.Cells(i, CInt(ColumnX.Text))
    stry = oUsedRange.Cells(i, CInt(ColumnY.Text))
    strz = oUsedRange.Cells(i, CInt(ColumnZ.Text))
    Dim x As Double, y As Double, z As Double
    x = oPartDoc.UnitsOfMeasure.GetValueFromExpression(strx, kDatabaseLengthUnits)
    y = oPartDoc.UnitsOfMeasure.GetValueFromExpression(stry, kDatabaseLengthUnits)
    z = oPartDoc.UnitsOfMeasure.GetValueFromExpression(strz, kDatabaseLengthUnits)
    Dim oPoint As Point
    Set oPoint = ThisApplication.TransientGeometry.CreatePoint(x, y, z)
    Dim oWorkPoint As WorkPoint
    Set oWorkPoint = oDef.WorkPoints.AddFixed(oPoint)
    Call oWorkPoint.AttributeSets.Add("ImportedFromExcel").Add("Index", kIntegerType, i)
    oPoints.Add oWorkPoint
    Next
    Dim oClientFeatures As ClientFeatures
    Set oClientFeatures = oDef.Features.ClientFeatures
    'Create a client feature definition by adding the selected items
    Dim oClientFeatureDef As ClientFeatureDefinition
    Set oClientFeatureDef = oClientFeatures.CreateDefinition("Imported Work Points", oPoints.Item(1), oPoints.Item(oPoints.Count))
    Dim oCFE As ClientFeatureElement
    For Each oCFE In oClientFeatureDef.ClientFeatureElements
    oCFE.BrowserVisible = True
    oCFE.UserEditable = True
    oCFE.HighlightWithFeature = False
    Next
    ' Create the client feature
    Dim oClientFeature As ClientFeature
    Set oClientFeature = oClientFeatures.Add(oClientFeatureDef, "ImportedWorkPointsClientId")
    Dim oSketch3D As Sketch3D
    Set oSketch3D = oDef.Sketches3D.Add
    If bCreateSpline Then
    Dim oSpline As SketchSpline3D
    Set oSpline = oSketch3D.SketchSplines3D.Add(oPoints)
    If bCloseSpline Then
    oSpline.closed = True
    End If
    End If
    If bCreatePolyline Then
    For i = 1 To oPoints.Count - 1
    Call oSketch3D.SketchLines3D.AddByTwoPoints(oPoints(i), oPoints(i + 1), False)
    Next
    If bClosePolyline Then
    Call oSketch3D.SketchLines3D.AddByTwoPoints(oPoints(oPoints.Count), oPoints(1), False)
    End If
    End If
    Set oSpline = Nothing
    Set oSketch3D = Nothing
    ThisApplication.UserInterfaceManager.UserInteractionDisabled = False
    ThisApplication.ActiveView.Fit
    Unload Me
    xSheet = "Sheet" & j
    Sheets(xSheet).Select
    Next j
    End Sub
    Private Sub CancelButton_Click()
    Unload Me
    End Sub
    Please use plain text.
