Autodesk Inventor
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
Need help to automate inventor
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
HI All,
I am new for the Autodesk, I have 5 year of experince in .net (C#) programming. I want to automate the autodesk inventor software. Basically my need is to automate design of Base Plate of a Pole.
My requirement is that, i will build an application that will read all the input from any .csv file and will call the inventor API and it will create the design and will save at hardrive.
First of all i want to know, Does Autodesk API provide such functionality to automate the whole process?
Thanks in Advance.
Re: Need help to automate inventor
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
You have lots of options here depending on what level of automation you require.
Inventor will read in fom an Excel spreadsheet nativly, so you can set this up maually and then use iLogic or VBA to save out the copies on the appropriate trigger.
iLogic itself has an API for accessing Excel spreadsheets, so you can automate the whole thing with iLogic if you need to.
http://inventortrenches.blogspot.co.uk/2011/04/usi
If you want to run this independatly of Inventor, you can use the API which accepts VBA, VB.net C and C#
http://usa.autodesk.com/adsk/servlet/index?siteID=
If you want to run this via a web client look at Inventor Intent:
http://wikihelp.autodesk.com/Inventor_ETO/enu/2013
@CadSetterOut
Please use the
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
You can access API supporting documentation from within inventors API window by firing the help on any function.
there is also a customisation forum under inventor discussions forums. There are lots of helpful people there as well.
Inventor 2014 Pro on Windows 7, 64bit
(please give Kudos or Tag as Solved if your issue is resolved)
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Thanks for your reply..
Sorry i did not understand your line "You can access API supporting documentation from within inventors API window by firing the help on any function." Form where i can access Inventor API Window?
I am new to autodesk so may be i am annoying you...
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
hi,
while in inventor Alt+F11
or
ribbon, manage tab, vba.
the application project will be visible in the API window. if you have a document open, the document project will also be visible in the API window.
the application project is targeted in inventor, tools, options, file tab, default vba project.
there is some helpful resources around. start in the inventor, customisation forums.
http://forums.autodesk.com/t5/Autodesk-Inventor-Cu
ps- also a favorite and skilled person for anyone to search posts from is :
Brian Ekins, Autodesk Inventor API
