• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    IlliniDawn
    Need Help Creating Punch Tool
    181 Views, 5 Replies
    02-22-2013 11:58 AM
    Please help!!!
    I'm new to Inventor and am trying to create a sheet metal punch tool, however, I must have something incorrect because the extract iFeature does not seem to be working.
    I've attached a copy of the file I'm currently working on.
    Thanks!
    Please use plain text.
    Re: Need Help Creating Punch Tool
    02-22-2013 01:13 PM in reply to: IlliniDawn
    Do not constrain Sketch 2 to the origin, this is one time when you don't fully constrain a sketch.
    After removing the Coincident Constraint from Sketch2 you should be able to drag the sketch without breaking Sketch3.
    Sketch3 needs some work (one thing I noticed is odd sized fillets and the sketch is not robust (fails after moving Sketch2).
    Sketch3 should only reference Sketch2 (and I wouldn't use an geometry projected from solid, only projected from Sketch2).
    I would give meaningful names to Sketch2 and 3.
    IlliniDawn
    02-25-2013 06:01 AM in reply to: JDMather
    JDMather.  Thank you so much for your help.  I'm used to working in Solidworks, and Inventor is taking a little for me to get used to!
    02-25-2013 06:18 AM in reply to: IlliniDawn
    Post back if you still can't figure it out.
    In Inventor you model the punch feature while in SWx you model the punch tool.
    IlliniDawn
    02-25-2013 06:58 AM in reply to: JDMather
    With your suggestions I was able to figure it out.
    I just have to get used to thinking about things in a slightly different way.
    Thanks again for your help.  I don't know if I would have figured it out without you!!
    02-25-2013 07:11 AM in reply to: IlliniDawn
    Another tip, because you don't constrain to the origin like you normally do - I sometimes add a Fixed constraint to make sure that I have everything properly defined so that the punch tool will update properly as placed or changed size and then delete the Fixed constraint before saving the punch feature.
