• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Valued Contributor
    My iTrigger is not working.!?, and i need to remove the dialog boxes.!
    209 Views, 3 Replies
    08-12-2012 11:24 PM
    Hi.... 2 things..!
    1. I have been trying to get iTrigger working, but so far without luck.
    I have tried..:
    trigger = iTrigger0
    and
    i = iTrigger0 (i saw this in another rule somewhere.)
    both in the beginng of my rule, but doesn't seem to make any diffrence.
    im not sure if theres something in the rule that is preventing the trigger from working, it´s copy-pasted from this forum.!
    2. Also, i would like to set a trigger event for this rule, but would like to have all the dialog boxes removed, when the rule is activated. I want the choises to be preset in the rule.! it should just be like a background process when the event triggers :smileyhappy:
    Heres the rule i want to trigger..: so 1. iTrigger is not working and 2. remove dialog boxes when the rule is activated
    trigger = iTrigger0
    question = MessageBox.Show("Are you sure you want to change the units of measure?", _
    "iLogic",MessageBoxButtons.YesNo)
    If question = vbNo Then
    Return
    Else
    'get input from user
    oUnit = InputRadioBox("Select a units of measure type", "Metric", "Imperial", True, "ilogic")
    'create precision value list
    oPrecisionArray = New String(){0, 1, 2, 3, 4, 5}
    oPrecision = InputListBox("Select the number of decimal places to use for the units of length display.", _
    oPrecisionArray, 1, "iLogic", "Decimal Places ")
    'example UnitsTypeEnum Enumerators
    'kCentimeterLengthUnits = 11268
    'kMillimeterLengthUnits = 11269
    'kInchLengthUnits = 11272
    'kKilogramMassUnits = 11283
    'kGramMassUnits = 11284
    'kLbMassMassUnits = 11286
    If oUnit = True Then
    'set to millimeter
    oUOM_1 = 11269
    'set to kilogram
    oUOM_2 = 11283
    Else
    'set to inch
    oUOM_1 = 11272
    'set to pounds mass
    oUOM_2 = 11286
    End If
    'Define the open document
    Dim openDoc As Document
    openDoc = ThisDoc.Document
    'set length units for the top level assembly
    openDoc.unitsofmeasure.LengthUnits = oUOM_1
    'set mass units for the top level assembly
    openDoc.unitsofmeasure.MassUnits = oUOM_2
    'set precision
    openDoc.unitsofmeasure.LengthDisplayPrecision = oPrecision
    'Look at all of the files referenced in the open document
    Dim docFile As Document
    For Each docFile In openDoc.AllReferencedDocuments
    'format file name
    Dim FNamePos As Long
    FNamePos = InStrRev(docFile.FullFileName, "\", -1)
    Dim docFName As String
    docFName = Right(docFile.FullFileName, Len(docFile.FullFileName) - FNamePos)
    'set length units
    docFile.unitsofmeasure.LengthUnits = oUOM_1
    'set mass units
    docFile.unitsofmeasure.MassUnits = oUOM_2
    'set precision
    docFile.unitsofmeasure.LengthDisplayPrecision = oPrecision
    'rebuild to update the display
    docFile.Rebuild
    Next
    End If
    'update all
    iLogicVb.UpdateWhenDone = True
    Please use plain text.
    Curtis_Waguespack
    Re: My iTrigger is not working.!?, and i need to remove the dialog boxes.!
    08-13-2012 06:46 AM in reply to: LSA-skan
    Hi LSA-skan,
    The trigger issue was the update when done line at the end:
    'update all
    This prevented the trigger parameter from updating at the top of the rule as needed, and therefore the rule would not run. Changing the line to update InventorVb.DocumentUpdate() resolves this.
    I've removed the input message boxes in the code as well.
    I hope this helps.
    Curtis
    trigger = iTrigger0
    'set to millimeter
    oUOM_1 = 11269
    'set to kilogram
    oUOM_2 = 11283
    'set precision
    'format  file name
    'set length units
    'set mass units
    'set precision
    docFile.unitsofmeasure.LengthDisplayPrecision = 3
    docFile.Rebuild
    Next
    'update all
      solution.png  Did you find this reply helpful ? If so please use the Accept as Solution or  Kudos button below.
    Valued Contributor
    08-13-2012 11:08 PM in reply to: Curtis_Waguespack
    Hi Curtis
    The boxes are now removed..! Nice :smileyvery-happy: 1 kudos for that.!
    However the iTrigger is still not doing anything. Is it becuase i have the rule in External, instead of In Document?
    Which leads me to another thing.. i would like the rule and iTrigger to work for all my documents, both old and new ones...! is that possible?
    /LSA-skan
    Valued Contributor
    10-24-2012 04:47 AM in reply to: Curtis_Waguespack
    Hi Curtis
    When i use the code you posted it always sets the Decimal to 1, even though it is set to 3??!what is wrong?
    /LSA-Skan
