• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Valued Mentor
    Rich.O.3d
    Re: My drawing hatch is so precise...
    06-25-2012 03:15 PM in reply to: moretti999
    First inventor converts the angle to radians then to fractional degrees then to decimal degrees, it then applies an analogous algorithm based on the colour of the 5th nearest star from earth multiplied by the deriviative of........
    I get this too...it drives me nuts
    Are you using a metric template, I am
    I suspect that is where the issue comes from...inventor not quite knowing how to convert all the numbers properly so in the math that drives the auto hatch angle, there is a rounding issue.
    CAD Management 101:
    You can do it your own way,
    If its done just how I say!
    [Metallica:And Justice For All:1988]
    Please use plain text.
