• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Distinguished Contributor
    My drawing hatch is so precise...
    468 Views, 10 Replies
    05-14-2012 11:15 PM
    ...I launch space ships with it.
    ______________
    Inventor Pro 2012
    Vault Pro 2012
    Please use plain text.
    Re: My drawing hatch is so precise...
    05-15-2012 06:31 PM in reply to: Vlad.Makarov
    Hmm, I guess I'm the only one whose Inventor gives wacky default hatch values?
    ______________
    Inventor Pro 2012
    Vault Pro 2012
    Talayoe
    05-15-2012 07:47 PM in reply to: Vlad.Makarov
    lol! I suppose you should charge extra for whatever that hatch is attached to and charge it out as 'extremely precision' or something of the similar.
    Btw, I havent seen this on mine and use it all the time. It is quite funny tho :smileywink:
    Inventor 2013 PDS
    trumpy81
    05-15-2012 09:28 PM in reply to: Vlad.Makarov
    Vlad, after using Inventor for a while and trying to track down reasons for assembly constraint failure, then numbers like that are common.
    Why is Inventor so pedantic about numbers? .... lol
    And Vlad, here's a challenge for you, try to measure that angle with your protractor .... lmfao!
    Regards
    Andy M
    Autodesk Inventor 2013 Pro SP1.1, Win7 Pro - 64Bit - SP1, Intel i7 960 @ 3.333 GHz
    Asus X58 Sabertooth, Corsair 12Gig DDR3, AMD Radeon HD6970, Samsung 830 Series 256G SSD, 2x 3TB Seagate, 2x 2TB Hitachi,
    1x 1TB Samsung, 4 x 2TB Seagate in Netgear ReadyNAS NV+, Dual Asus VE278Q Monitors
    Employee
    jozef.dubaj
    05-17-2012 02:32 AM in reply to: Vlad.Makarov
    Hi Vlad,
    From where did you get the drawing? Created by you or received from someone? I\m curious whether did you enter value of 30 deg and then you found there 30.00022219255. Or you just received the drawing and check the hatching angle
    -Jozef
    GSE_Dan_A
    05-18-2012 07:42 AM in reply to: Vlad.Makarov
    I win! This was from a hatching of a section I just made.  No changes made... straight from the Inventor Realm
    GSE Consultants Inc.
    Windsor, ON. Canada
    mrattray
    05-18-2012 11:05 AM in reply to: GSE_Dan_A
    Did anyone notice that the error in those two hatch pattern are exactly the opposite? If you add them together you get 90.00000000000000.
    Mike (not Matt) Rattray
    Valued Contributor
    Hell-If-I-Know
    05-18-2012 01:17 PM in reply to: mrattray
    What are the odds?
    05-18-2012 01:53 PM in reply to: jozef.dubaj
    jozef.dubaj wrote:
    Hi Vlad,
    -Jozef
    Hi Jozef,
    The drawings are my own. I see the wacky values when I change the hatch style.
    It is happening in section views of assemblies.
    ______________
    Inventor Pro 2012
    Vault Pro 2012
    05-18-2012 02:07 PM in reply to: Vlad.Makarov
    Volodya,
    This is the value for Imperial degrees:smileylol:
