• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Active Member
    Multiple items insertion
    40 Views, 5 Replies
    12-05-2002 07:00 PM
    Hi everybody, everything's OK?. Do anybody else can help me resolving this problem? I will like to insert a bolt, washer, nut, ecc. and constraint once each time, but I wish a detailed parts list of the final assembly, detailing any single bolt, washer, ecc.
    Thanks for your brain time, thanks for readig.
    AOG
    Giovanni
    Please use plain text.
    *Keller, Kent
    Re: Multiple items insertion
    12-06-2002 01:33 AM in reply to: mariox
    Not sure I understand, but can you make the bolt, washer, and nut a sub assembly to cut
    down on the constraints needed each time?
    Kent
    Member of the Autodesk Discussion Forum Moderator Program
    "mariox" wrote in message news:f12a262.-1@WebX.maYIadrTaRb...
    > AOG
    > Giovanni
    Active Member
    Re:
    12-08-2002 06:42 PM in reply to: mariox
    Yes, I will like to insert an assembly, but when I make the parts list, I will like a detailed parts list specifying both the bolt, nut, washer, ecc. Instead, the program specify only the sub assembly with the name I gave it.
    Thanks a lot Kent
    *Maas, Karl
    Re:
    12-08-2002 10:08 PM in reply to: mariox
    When you first insert your parts list, you have the
    option to show top level parts only or ALL parts.
    K
    Yes,
    Thanks a lot Kent
    Active Member
    Re:
    12-08-2002 10:34 PM in reply to: mariox
    Ok, it does work, but now there are a lot of items that belong to other sub assemblies and should not appear in the parts list, thanks again and again.
    *Keller, Kent
    Re:
    12-09-2002 01:07 AM in reply to: mariox
    Yes, unfortunately you have to hide each of those unwanted rows in the list.
    Kent
    "mariox" wrote in message news:f12a262.3@WebX.maYIadrTaRb...
