Autodesk Inventor
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
Multiple base view properties
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I have a drawing that has multiple base views on it. These are parts of an assembly that need detailed. I do not wish to create 50+ separate drawings for all of these details. Each part needs the iproperties from their model placed on the sheet next to the part.
I can place the first part's iproperties using the Format Text dialog box and getting the iproperties from the part model without any problem. When I try to do the same with the second base view I've placed on the drawing it still gives me the first part's iproperties.
Is it possible to do what I want without manually writing the iproperty text for each part? It there a better way than what I am doing?
Thanks in advance!
Senior Designer/ CAD Programmer
Howden North America
Using Inventor 2013
Re: Multiple base view properties
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
From what I can tell, notes placed on the drawing will take all the iproperties from the first model placed as a view. However, notes attached with a leader will take iproperties from the model in that view. I'm not sure if there is any other way to force this to work.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Good enough. I'll just delete the leader afterwards!
Thanks!
Using Inventor 2013
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Depending on how you designed your titleblocks, you may have a problem there as well. If it was set up to use Model Properties, it will grab those from the first model placed. We use a special titleblock for what you are describing, that pulls it's values form Drawing Properties.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Try this...edit your View Identifier in your Styles Editor. Not only can you have it display the View Name and View Scale, but you can also add any Model Properties. Let's say you wanted the material listed with each base view...edit the View Identifier in the Styles Editor and add the "Material" property to your text. Each time you place a base view and turn on the View Identifier, the material will display for the part in that view. After the view is placed, you can move the View Identifier to a different location around the view, if you don't want it directly underneath.
Please select "Accept as Solution" if this answers your question.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
This is way better than what I was trying to do.
Thanks!
Using Inventor 2013
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Your suggestion has been working great. Just to raise the bar a bit... Is there a way to get the item number from the assembly to show up in the view identifier or a note also?
Using Inventor 2013
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
That's a tough one because a parts list is connected to a specific assembly view. When creating a parts list, you have to select the view you want to create item numbers for. I've encountered this question before and I don't think we came up with a solution, but let me revisit this and think about it.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I'd appreciate any help.
Using Inventor 2013
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Well, there doesn't seem to be any way to do this...at least not that I can come up with. I have submitted this topic to the Inventor IdeaStation (Wishlist), so maybe we'll get lucky and the developers will consider adding such functionality.
Here's the idea that I added: http://forums.autodesk.com/t5/Inventor-IdeaStation![]()
